| | #1 |
| Pebble Pounder Join Date: Aug 2005 Location: San Francisco
| Is this a good custom setup:(Cell) Intellect 1400 2/3A(Configuration) Flat Hump (Plug) Large Female Tamiya(Wire) 14AWG Wire |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
| Give us a bit more info... What's it going in? (ie: Clod, TXT, TLT, Maxx, etc..) What motor(s) are you using? How many cells are in the pack? The 1400mah Intellect cells are a nice cells to use. |
| | #3 |
| tlt 55t lathe, TR2, 7 cells |
| | #4 |
| That's close to what I'm running in my TLT. I've got a 6 cell pack of the same batts and it works just fine. |
| | #5 |
| Rock Crawler Join Date: Sep 2005 Location: wyckoff, NJ
| i have the exact battery in my tlt and i love it |
| | #6 |
| how long does this pack last? |
| | #7 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| You should get near a half hour with that pack, depending on how you drive. I like the 55t lathe motors on 7 and 8 cells. |
| | #8 |
| 31st place in 2006 Nats!! ![]() Join Date: Feb 2004 Location: Columbia Gorge
| All is fine EXCEPT for that power robbing Tamiya plug. Time to upgrade. I bet 90% of the RCC board runs Deans plugs. |
| | #9 |
| ok think im set. know to find a crawl spot in SF |
| | #10 |
| Your axles are Puny! ![]() Join Date: Aug 2006 Location: Nowhere, Wy :(
| how does the Tamiya battery plug rob power? |
| | #11 |
| Rock Crawler Join Date: Dec 2004 Location: Grand Forks, ND
| it has resistance. resistance restricts the flow of power from the battery. and in turn turns that power into heat. which will probably melt your plugs in the long run. and they have been known to catch fire too. same thing with bullet style motor connectors. |
| | #12 |
| So Dean Plugs are the way to go? how much more time will i get out of a 8-Cell 2000mAH 7.2v battery? |
| Thread Tools | |
| Display Modes | |
