Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: looking to get into it
Old 07-28-2006, 08:43 PM   #1
Default looking to get into it
hey guys. i am looking to get into the scale scene of rc. i have a few other r/c so im not really new to the hobby, just crawling. I want to make myself a chassis. What type of metal should i use. and what esc set up should i run. im going to be mudding, crawling, driving on the beach, and some some mountain bike trails. i want a all around truck. not just strictly crawling. what motor and ESC should i use?
Hemi-maxx14 is offline   Reply With Quote
Old 07-28-2006, 08:54 PM   #2
not sure on what electronics to use but for the chassis it depends. since you said that you want it to not just be a crawler i would do one like burrlytlt did
://www.rccrawler.com/forum/showthread.php?t=37067
nitrorc2332 is offline   Reply With Quote
Old 07-28-2006, 09:06 PM   #3
no, i want to build the chassis. i just need to no what matirial
Old 07-28-2006, 09:22 PM   #4
I <3 LS3
exesivefire's Avatar
whatever you want to use, we have used anything from aluminum to lexan to brass to steel to tubing...
poke around a bit.. there are a ton of buildups in her that shoudl give you ideas as a starting point
exesivefire is online now   Reply With Quote
Old 07-28-2006, 09:30 PM   #5
put isnt it good to have some wieght
Old 07-28-2006, 10:29 PM   #6
if you have the equipment take a piece of 1/2 square tube bend it then cut it down the center thats how i build the csc1
or i could cut you two frame rails like i make for the CSC1 for very cheap and you could do the rest... itll save you from doing the really hard stuff.
would basically just be the two chassis strips
peej410 is offline   Reply With Quote
Old 07-28-2006, 10:49 PM   #7
well wieght is a big factor. can i build it out of derlin. and i might be able to get my hands on some CF. but will just some sheet air craft aluminum work?
Old 07-28-2006, 10:51 PM   #8
usually scale is a compromise between aesthetics and performance. which is more important to you ?
you can make it out of whatever you can dream of!
Old 07-28-2006, 10:57 PM   #9
does aesthetics mean appearance? and can i just make up for the wieght somewere else?
Old 07-28-2006, 11:15 PM   #10
yes aesthetics means appearance, the idea behind most performance oriented rigs scale or otherwise is to keep the weight as low as possible this usually means making as light a chassis as possible without compromising durability. then you add the weight to the wheels usually.
Old 07-28-2006, 11:37 PM   #11
cool cool
Old 07-29-2006, 12:24 PM   #12
I am on my way to lowes today to see what they have. If they do not have the stuff that i want it is of to the hunt for carbon fiber!
