Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: cantilevers or not?
Old 07-29-2006, 04:51 PM   #1
Arrow cantilevers or not?
Im going to get a new txt. I just want to know wether i should stick with the cantulevers or switch to a more traditional way with no cantilevers if i should switch what kind of shocks should i get and what do i have to do thanks for the help.
matt423 is offline   Reply With Quote
Old 07-29-2006, 08:24 PM   #2
You are better off switching to a shock that is mounted directly to the axle. Better control, helps to fight torque twist, and cuts down on the unreal articulation you can get out of cantis.
I have run everything from Maxx shocks, to savages, and 2 different flavors of the MGT shock. Personally I prefer the MGT shocks. Longer than a Maxx, bigger diameter, and seem to hold up to a beating better. If you go MGT put a Gold spring on the passenger side rear to fight off torque twist. With Maxx shocks go with stock red or losi yellow springs.
If you wanna go savages, be prepared to make some custom mounts so that they will work right.
bustedcrawler is offline   Reply With Quote
Old 07-29-2006, 09:16 PM   #3
Integy MSR4 shocks are also very good; ~4", alum, pivot balls at each end.
Mazlem is offline   Reply With Quote
Old 07-30-2006, 12:27 PM   #4
What modifications would i have to do to run savage shocks?
Old 07-30-2006, 04:07 PM   #5
I hate to say it, but "Use the search feature" Look for Savage in the TXT forum, also search for Roctapus. There is a ton of info and pics on this site. The Search button is you friend, get to know him, learn to love him.
redbeard is offline   Reply With Quote
Old 07-30-2006, 06:14 PM   #6
2006 2.2 National Champ
BENDER's Avatar
You'll have to fab some shock towers, for the Savage shocks to work right.
Like so....
"ROCTAPUS"
BENDER is offline   Reply With Quote
Old 07-30-2006, 09:53 PM   #7
^^ you were new to the site!!!
Wow
Back on topic. if you make a tuber it cant use cantsayit. The direct setup is a lot more practical(I said that )
revoster is offline   Reply With Quote
