Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: how long
Old 07-29-2006, 07:46 PM   #1
Default how long
how long should a 3300 at 2 amps or 3 amps charge for?
how long should a 3000 at 2 amps or 3 amps charge for?
Warn Off Road is offline   Reply With Quote
Old 07-29-2006, 08:39 PM   #2
Well technically, a 3300mah pack will take about 1 hour at 3.3amps, and the 3000mah pack at 3.0amps about 1 hour.
So with your question... the 3300mah pack at 2amps will take about 1.65 hours. And at 3amps, about 1.1 hours. 3000mah is easier to determine... At 2 amps, 1.5 hours. At 3amps, 1 hour.
These are rough estimates, its best to use a peak charger with NiHM batteries so not to over charge them and damage them.
Cake Eater is offline   Reply With Quote
