Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: Spacers?
Old 07-30-2006, 01:32 PM   #1
Thumbs down Spacers?
Could somebody tell me where i could find some sort of hard plastic tube that a bolt can go through? I need something like that to put my pede tranny inbetween my frame rails on my latest project.
rockwell is offline   Reply With Quote
Old 07-30-2006, 01:52 PM   #2
Home Depot has some nylon/plastic spacers in different lengths. I've had some in 1/2" and 3/4" lengths with about a 1/8" inside diameter hole. I know they make them shorter and I believe they have longer ones too. Just check the hardware(nut/bolt) section...
Otherwise, check online at www.McMaster.com. and type in 'spacer' into the search field. pick what you want from Aluminum, Steel, Plastic and so on in different lengths and sizes.
Cake Eater is offline   Reply With Quote
Old 07-30-2006, 03:19 PM   #3
Use metal spacers if possible so they won't compress when you tighten everything down. www.mcmaster.com is a great resource, and you can start your search looking for P/N 92510A. Good luck with the project!
CPE MT is offline   Reply With Quote
Old 07-30-2006, 04:19 PM   #4
Go to Lowes or HD and get a gray or white 3/8" poly plastic supply line for a toilet. They have a thick well so you can tighten down on it without crushing. Comes in various lengths. Just cut to size needed.
scruff007 is offline   Reply With Quote
