01-15-2013, 07:54 PM | #1 |
Newbie Join Date: Jan 2013 Location: Home
| Primal radiant charger and speedpack 3300 6cell Nimh battery
Very much a newbie and trying to read up but figured I would ask this question here. I have the above charger and 2 batteries for my new RTR wraith. Honestly it's like the manuals are in a different language to me and being a techie guy it's been frustrating (lots to learn). I am getting about 5-10 minutes of run time with the truck on a charge. At least I assume the charge is going dead as it seems to run ok for several minutes then starts stuttering when I give it throttle (both forward and reverse). Maybe I am not charging the batteries correctly? What amp setting should I use on the charger, I have been using 3 amps. Is this possibly causing the batter to not fully charge and thus the low runtime? Is the stuttering after running a few minutes likely something else or is that what this does when the battery gets low? Appreciate the feedback and help. While I am at it, what do people do to keep this thing from rolling as much? Seems to roll quite easy! Thanks again! |
01-15-2013, 08:18 PM | #2 |
Rock Stacker Join Date: Jan 2013 Location: Ohio
| Re: Primal radiant charger and speedpack 3300 6cell Nimh battery
Charging at that rate should be fine. Are your battery's hot when your done running? Unfortunatly your charger doesn't let you know how many mah your are putting back into the battery. Without that, I am not really sure how else to diagnose your battery. To me, it doesn't sound like a battery issue but an interference issue. I could be wrong.
01-15-2013, 09:23 PM | #3 |
Quarry Creeper Join Date: Jun 2010 Location: lexington nc
you say the truck is rtr so i asume its stock esc did u by chance turn off the low voltage dectecion on the esc i had the same issue when i first got mine. i turned off the low voltage an boom no more stutter
01-15-2013, 11:56 PM | #4 |
I did read something about the low voltage detection. I will go down that path (yes, stock esc). Thanks for the suggestion and I will report back with findings..
01-16-2013, 05:54 AM | #5 |
| Re: Primal radiant charger and speedpack 3300 6cell Nimh battery Interesting. I just leave the low voltage on in my Slash so I don't have to think about changing the settings. Thanks for bringing up a potential issue.
01-16-2013, 11:48 AM | #6 |
Yep. That was it. Reprogrammed to remove the cutoff and seems to be running well! Thanks for all the information..
01-16-2013, 04:32 PM | #7 |
yw an enjoy this addicting hobby ive been in this since i was 14
Primal radiant charger and speedpack 3300 6cell Nimh battery - Similar Threads | ||||
anyone ever use primal radient charger help please | hardknox | Newbie General | 3 | 07-05-2012 12:36 PM |
Battery Charger for Lipo and NIMH. | simoniz | Electronics | 7 | 10-19-2010 06:46 PM |
how many rpms (55t 6cell nimh) | nd4spdbh | Electronics | 9 | 03-11-2008 06:47 PM |
