02-20-2013, 10:41 AM | #1 |
Rock Stacker Join Date: Jan 2013 Location: Charlotte
| Throttle trim problem
So i'm having a problem with my throttle trim/ESC I believe. I have everything set up correctly I believe but when I turn on the ESC the car wants to move on it's own. I have the trim turned all the way down but it still wants to barely crawl. Any help is appreciated! Below is my setup. Car: SCX10 ESC: Novak Goat 3s Motor: Novak Ballistic 21.5t Brushless Radio: Tactic TTX240 2 channel 2.4ghz Receiver: Tactic TACL0324 3 Channel Servo: Hitec 5645 Digital Servo BEC: Castle 10amp BEC (Directly connected to Servo) Battery: Zippy Lipo 3s 3000mah 40c |
02-20-2013, 12:30 PM | #2 |
Rock Crawler Join Date: Jan 2006 Location: Phoenix
| Re: Throttle trim problem
try re-calibrating your esc to your radio that should fix it also set your throttle trim back to neutral/center before you do that
02-21-2013, 05:20 AM | #3 |
This worked perfectly. Thank!
02-21-2013, 07:53 AM | #4 |
Rock Crawler Join Date: Oct 2009 Location: Washington State
If the problem comes back, check your dead band settings. I just had to increase mine because the throttle did not have enough "room" on the dead band, and it wanted to creep one way or the other.
Throttle trim problem - Similar Threads | ||||
Need more throttle trim; is there another option? | gr8_outdoors | Newbie General | 13 | 07-24-2011 06:39 PM |
using throttle trim to drag brake | papaweely | Electronics | 11 | 04-02-2011 10:34 AM |
forward throttle trim not working | pcsourced | Losi Mini-Rock Crawler | 23 | 08-12-2009 09:08 AM |
DX3 throttle trim ?? | BigSki | Electronics | 7 | 11-14-2008 07:09 PM |
Throttle trim as a brake | ksean6969 | HPI Wheely King | 3 | 09-07-2007 05:22 PM |
