04-07-2013, 04:03 PM | #1 |
Newbie Join Date: Nov 2009 Location: Milford
| Losi Night Crawler question. Losi Night Crawler on a stone wall - YouTube Seems like it is binding up as I drive, thought it might be axle or gear box related, someone else suggested maybe a ESC or Motor issue. Please HELP! |
04-07-2013, 04:33 PM | #2 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
| Re: Losi Night Crawler question.
You just recently buy this? Losi's need regular maintenance particularly the worm gears. Unless you've already been inside them recently, tear down both axles, clean and lube the worms, check all the bearings for smooth and make sure your driveshafts don't have broken pins or other problems. All the tranny gears are external and you can inspect them without teardown. Post questions like these in the TeamLosi forum and read thru numerous similar threads there.
04-07-2013, 08:40 PM | #3 |
Rock Stacker Join Date: May 2012 Location: Toronto
When u say binding like it just has no power to go over stuff ?
04-07-2013, 11:57 PM | #4 |
Newbie Join Date: Oct 2012 Location: Miami
Can you be a bit more specific on what ypu mean by binding so that I can help you if I can!
04-08-2013, 01:10 AM | #5 |
Search the LCC/LNC sub forum for "worm stall" and you might find an answer. If it's the occasional stops seen in the film that bothers you it seems like these are more related to the combination of the fairly weak 35T motor and less capable batteries. (See the indicator LED on the ESC at the rear.) Last edited by Olle P; 04-08-2013 at 01:14 AM. |
Losi Night Crawler question. - Similar Threads | ||||
Losi night crawler question | sullysracin | Electronics | 8 | 12-08-2012 07:48 PM |
Losi night crawler question | ktwohig9 | Team Losi Comp Crawler | 7 | 03-09-2012 07:42 PM |
Question about a BEC for a Losi Night Crawler | du4x4 | Newbie General | 1 | 01-06-2011 03:01 PM |
1/10 Losi Night Crawler body question??? | simoniz | Losi Mini-Rock Crawler | 7 | 10-22-2010 09:07 PM |
Losi Night Crawler question | Tdog | Newbie General | 4 | 04-02-2010 09:53 AM |
