Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Are all Ca glues alike?
Old 06-07-2013, 09:37 AM   #1
Default Are all Ca glues alike?
I've been making wood pens for years and use ca glue for numerous applications. Can I use the same ca for my rc rim to tires.? I'm on my firsts build.
This is my main ca glue
But I use this as well which can be purchased at hardware stores.
Last edited by tzcidvz; 06-07-2013 at 09:55 AM. Reason: Pictures didn't post from iPad
tzcidvz is offline   Reply With Quote
Old 06-07-2013, 09:45 AM   #2
Scale Detail Engineering
Default Re: Are all Ca glues alike?
No.
Standard CA glue dries brittle.
Tire CA glue dries a little flexible so works much better on tires.
Here's what I've used: http://crawlerinnovations.com/index....mart&Itemid=70
johnnyh66 is offline   Reply With Quote
Old 06-07-2013, 09:56 AM   #3
Thanks you've saved me from myself.
Old 06-10-2013, 02:50 AM   #4
To broaden this subject one can say that CA glue comes in many different varieties.
The most apparent difference is viscosity before curing. Can be anywhere from "gel", used to build stuff or cross gaps, to "water" using the capillary effect.
Then there are differences in what can be glued with them. Some are better for metal and others for glass. Most have trouble with greasy plastics.
Olle P is offline   Reply With Quote
Old 06-10-2013, 08:10 AM   #5
I have used this stuff with good results. Can get it in most hardware stores as well.
RUBBER TOUGHENED - Bond line isn't brittle and doesn't crack under pressure
Gorilla Glue - Super Glue
jaloos is offline   Reply With Quote
Are all Ca glues alike? - Similar Threads
Glues for gluing lexan Armistice Paint and Body 4 10-29-2012 07:55 PM
Trail Ready 1.9 Beadlock look alike? casperssammy General Scale Talk 5 04-11-2012 12:55 AM
Banners, Logo's, and alike designs Chris_The_Battery_Man Chit Chat 0 11-05-2010 09:11 AM
Glues? Willard Paint and Body 7 09-12-2010 10:23 PM
