06-17-2013, 06:01 AM | #1 |
Newbie Join Date: Sep 2012 Location: India
| AE2 ESC to Receiver wire/cable polarity & AE2 ESC switch position.
Hi .Well I am right now in the process of building a SCX 10 dingo.I need to know the polarity of the wires ( leading to the receiver ) the brown, red and yellow from the AE-2 ESC. I don't see any markings on it. Secondly how do I determine the "ON " and " OFF " position of the ESC switch? Again I don't see any markings on the switch.I need to know this for the first time set up of ESC isn't it?Pls let me know about these queries. Last edited by Tread Well; 06-18-2013 at 02:09 PM. |
06-17-2013, 06:37 AM | #2 |
| Re: AE2 ESC to Receiver wire/cable polarity & AE2 ESC switch position.
Brown wire goes to the outside. It's essentially the same as this one: For the switch, make sure your motor wires are hooked up and when you plug the battery in the first time, if the ESC turns on, then switch is in wrong direction. Just flip it the other way. It won't hurt anything. |
06-17-2013, 07:11 AM | #3 |
Thanks.But brown goes outside you said.which one right or left , s or ( -ve ) on the receiver?I have markings on my receiver.Its the wires from my AE2 which doesn't have .And are the colour coding (brown,red &yellow ) from ESCs a "standard" ? Or should I follow the same orientation / direction as marked for the battery on my Ae2 ESC? |
06-17-2013, 09:06 AM | #4 | |||
| Re: AE2 ESC to Receiver wire/cable polarity & AE2 ESC switch position. Quote:
As far as the switch, pick a position, if the ESC starts beeping at you as you're plugging in your battery, you'll know that was 'On', just simply turn it off. Then you can hold your trigger and turn it back on for calibrating. Quote:
06-17-2013, 09:17 AM | #5 |
Brown or black are always negative for servos or ESC.
06-18-2013, 07:34 AM | #6 |
| Re: AE2 ESC to Receiver wire/cable polarity & AE2 ESC switch position. [/IMG] Well from the image of my Axial AE-2 ESC you can see that I have Brown,Red and Yellow wires leading to the receiver.Now Am I to assume that Brown (Faded on photo) on the far right to be considered as -ve as the ESC to battery lead (as marked on the image) is also on the right side and then as the next wire " Red " on the left (middle) to be +ve and since the only one left out to be assumed as " SIGNAL " wire?Well if I had to guess, its a wild guess for someone like me a ...rc starter! |
06-18-2013, 10:16 AM | #7 | ||
*UNLESS* you want to hook up an external BEC to your receiver, in which case the red doesn't get connected to any pin. | ||
06-18-2013, 02:14 PM | #8 |
Thanks man.appreciated.well can't they just mark it like the batt terminals instead of making newbies go in circles.
AE2 ESC to Receiver wire/cable polarity & AE2 ESC switch position. - Similar Threads | ||||
How to waterproof your AE2 ESC, AR2 Receiver and LED light board. | noremacyug | Electronics | 9 | 07-09-2013 11:54 AM |
ae2 esc ? | chazekxt | Electronics | 13 | 06-24-2012 10:03 PM |
RX pack & ESC, remove the red wire or leave the ESC switch off | BenW | Electronics | 5 | 02-23-2005 06:25 PM |
