07-24-2013, 12:37 AM | #1 |
Newbie Join Date: Jul 2013 Location: Phoenix
| 2.2 Desert Rig needs transmission advice
I'm starting a build in the spirit of krawlfreaks Reaper build and could use some brains. It will be a desert rig, no crawling. I want to get rid of the transmission. My idea is to run a direct drive with a slipper clutch. If I am doing my calculations correctly around a 4.00 spur pinion ratio run thru front and rear diffs at 2.84 and with my tire size give me my top speed goal. No need for a Axial Trans. Imagine sort of like a direct drive setup on a pan car but a slipper clutch in the differentials place and imagine the axle as the output shafts of the drive line. I hope that made sense. Thoughts? |
07-24-2013, 06:33 AM | #2 |
RCC Addict Join Date: Nov 2010 Location: England
| Re: 2.2 Desert Rig needs transmission advice
why not use an transmission out of an 1/8th buggy or truggy as i have in my foff truck, version 2? I used a Tekno motor mount and 2 alloy upgrade trans mounts. Then made a mount for the spur gear. Although I used mod1 gears you could easily make a spur mount to fit 32 or 64 pitch gears. |
07-24-2013, 10:06 AM | #3 |
From what I can tell that looks like a direct drive. I want to include a quality slipper clutch to help with drive train shock off of jumps and flips and such. I have an idea using a robinson racing slipper. I'm trying to figure out if its going to work |
07-25-2013, 06:57 PM | #4 |
Solved I am going to use an upgraded slash 4x4 slipper clutch setup Thanks |
07-25-2013, 07:01 PM | #5 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
got a build thread yet? Sounds cool |
07-26-2013, 11:26 AM | #6 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
I am not exactly sure what the exo terra gear output is but it is a direct drive using diff oil, not slipper though
2.2 Desert Rig needs transmission advice - Similar Threads | ||||
Transmission Advice On a Budget!!! | alexchen86 | Axial Wraith | 4 | 04-25-2013 03:41 PM |
Glow's new rig - Need some advice.... | glondark | EnRoute Berg | 11 | 03-02-2013 06:07 PM |
1:1 Rig Advice | LR3 | Chit Chat | 33 | 12-16-2010 08:46 PM |
Transmission Advice | newb | Traxxas Crawlers | 21 | 05-31-2009 06:22 PM |
scale rig advice | KYScorpion | Newbie General | 3 | 04-04-2008 07:21 PM |
