| | #1 |
| Pebble Pounder Join Date: Sep 2006 Location: SW Charlotte
| well duh clod is a solid axle and the twin is a independent but both look the same how about the gearing? i prefer the independent setup for clearance reasons... EDIT: i am referring to twin detonator not twin force Last edited by roadblock; 10-11-2006 at 12:43 AM. |
| Sponsored Links | |
| | #2 | |
| It's a setup! ![]() ![]() ![]() Join Date: Jan 2004 Location: The Crawler State
| | #3 |
| ok now answer the question since i explained it a lil better... |
| | #4 |
| Quarry Creeper Join Date: Nov 2005 Location: Costa Mesa
| Clod axles have the motors mounted on them, twins don't and require a center mounted tranny. They are also both straight axles, not independent |
| | #5 | |
this the TAMIYA TWIN DETONATOR ![]() and here is the exploded view of the truck if u notice it looks like a independent CLOD axle, i just wanna know what the ratio are for this and the CLOD http://www.tamiyausa.com/pdf/exp/58309e.pdf | |
| | #6 |
| ... Join Date: Sep 2005 Location: USA
| YOur just wasting your time with that. When you get it all done you'll wish you just bought Clod axles. There is no way it will perform aswell as a clod. |
| | #7 |
| Pebble Pounder Join Date: May 2006 Location: Holland
| It has a higher internal gear ratio than the Clod gearbox. It'd probably just go too fast, even with adjustable motor mounts and small pinions. |
| | #8 |
| y was this moved to the noob section? |
| | #9 |
| I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
| gee I wonder? looking at the setup the housings are about 1/3rd bigger than the clod and much longer, you could use it but it would be a bear....go ahead and try it would be a good experiment. |
| | #10 |
| Colt Python/SR9c ![]() Join Date: Feb 2004 Location: out in the shop, reloading ammo!
| It was moved because if you think clod axles and TD axles look the same, then you seriously need to stay in this section. It will save you alot of hassle from other members. |
| | #11 |
| Quarry Creeper Join Date: Feb 2006 Location: Shillington
| Pitching the gearbox up will give you some ground clearance on the motors but creates steering issues. It also leaves no room for the links and shocks. Sell the sucker on EBay and buy some clod axels... It has been done.... Searching is your friend... Twin Detonator |
| | #12 |
| I wanna be Dave ![]() Join Date: Oct 2005 Location: Columbia TN
| I could see the how they could be confusing, there both black, made of plastic, and have wheels on them. |
| | #13 | |
| | #14 |
| PapaGriz Yo ![]() Join Date: Apr 2004 Location: Planning
| Send a PM to Gimbal, he built a Twin D. I think he locked out the suspension and 4 linked it. |
| | #15 |
| right, I was thinking twin force... eh, whatever.... Sorry, it's my first day here |
| Thread Tools | |
| Display Modes | |
