Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: help with motor wiring
Old 10-11-2006, 03:19 PM   #1
Default help with motor wiring
i am going to be going from the tlt's to a clod. i am wondering if my speedcontrol from my tlt would work with 2 silver cans? i plan on wiring it parallel, i just dont know if its going to be too much draw for the speed control. any help?
Click the image to open in full size.Runner Plus Reverse Digital LRP8305 Function -Forward,Brake,Reverse
Reverse Switchable- (for forward only racing)
Connections -4 wire and plugs
Overload Protection -yes Multi protection system
Motor limit -17turns
Voltage range - 4.8 to 8.4volts
Microprocessor - Digital
PWM Frequency - 1250Hz
Brakes - Yes EMK
On resistance - 0.017ohm
Maximum rate current @ 1sec - 80amp
Continuous current @ 30sec - 40amp
Continuous current for 5 minutes - 20amp
BEC - 5volts
Continuous BEC current @ 30seconds - 1.6amps
Continuous BEC current @ 5minutes-.6 amps
[FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=1]
'83 chevy is offline   Reply With Quote
Old 10-11-2006, 03:23 PM   #2
OCCUPY RCC!
dezfan's Avatar
Click the image to open in full size.Runner Plus Reverse Digital LRP8305Function
Reverse Switchable
Connections
Overload Protection
Motor limit
Voltage range
Microprocessor
PWM Frequency
Brakes
On resistance
BEC
4 wire and plugs
17turns
4.8 to 8.4volts
Digital
1250Hz
Yes EMK
0.017ohm
80amp
40amp
20amp
5volts
1.6amps
0.6amps
Probably not.
dezfan is offline   Reply With Quote
Old 10-11-2006, 04:42 PM   #3
I think the limit is for the lowest turn motor it can handle. My friend is using an LPR Runner and it works just fine.
ILoveRCRockCrawlin is offline   Reply With Quote
Old 10-11-2006, 10:14 PM   #4
well so used it
andres-tavares is offline   Reply With Quote
Old 10-12-2006, 03:34 PM   #5
Originally Posted by andres-tavares
well so used it
huh?
so anyways like ILRCRC said i think that the limit is the lowest turn. but from what i read two 27 turn motors wired in series is like one 54 turn motor to the speed control, so if it works with one 55 turn lathe than it should be able to handle two 27's. right?
