Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: Locking Pede Tranny
Old 10-12-2006, 09:00 PM   #1
Default Locking Pede Tranny
What is the best way to lock a pede tranny? Just simple use JB weld in the gears like the diff?
Coors is offline   Reply With Quote
Old 10-12-2006, 09:17 PM   #2
I'm a stupid C U N T!
slobin3d's Avatar
yup
slobin3d is offline   Reply With Quote
Old 10-12-2006, 09:59 PM   #3
teamtom's Avatar
I used hot glue the first time and after about 6 months it started to slip again!
15 minute epoxy and large metal shavings, it's not going anywhere now.
teamtom is offline   Reply With Quote
Old 10-12-2006, 10:05 PM   #4
Lowes sells this 2 part epoxy putty. Easier to work with then JB Weld plus, fully set in 3 hours.
RD400 is offline   Reply With Quote
Old 10-12-2006, 10:11 PM   #5
Mayor of Bedrock
freetimecrawler's Avatar
You can also get a plumbers 2 part clay like texture epoxy that sets hard as a rock in 20 minutes. I've locked axles and trannys with it with never a problem.
freetimecrawler is offline   Reply With Quote
Old 10-12-2006, 10:19 PM   #6
thanks for all the info guys. i will probably just use jb weld since I already have some and this thing won't really be running for a week or so.
Old 10-13-2006, 02:31 AM   #7
I'm partial to QuikSteel. it's only about $10 for a tube @ wal-mart. fast drying 2 part epoxy putty. bought it to patch up a gas tank (imprevious to chemicals, and will dry while wet). and have since used it to patch a radiator on the trail, aswell as an oil pan that rusted through! Great stuff.....
but yea...that's a great way to perma-lock a diff
Numbchux is offline   Reply With Quote
Old 10-13-2006, 07:47 AM   #8
Power of the Portals
I wouldn't use jb weld or epoxy... for the simple reason if you strip the teeth off the diff your sol unless you carry spares, IMO, here a better way of locking pede diff and you can take it a part if needed be.
Locking Stampede diff(no epoxy)
eric113 is offline   Reply With Quote
Old 12-22-2006, 12:04 AM   #9
this is a different way to lock the diff but it is interesting.
It is easy to lock the diff, just open it up, clean the grease out, and put jb weld or i used gorilla glue in mine to set the diff gears inplace
Rc EnthuSiasTs is offline   Reply With Quote
Old 12-22-2006, 07:55 AM   #10
go with erics way..... lock it and leave it...
savagecrawler is offline   Reply With Quote
Old 12-22-2006, 11:26 AM   #11
i am an idiot, i posted the same link as eric, i didn't even seen his link. Sorry
Old 12-27-2006, 02:23 PM   #12
mechanical lock should be much better than epoxy or jb
sack is offline   Reply With Quote
Old 01-09-2007, 10:26 PM   #13
Talking
u can use almost anything that will seis up the gear in one of my crawlers i used solder this in my new recent crawler i just used apoxi good luck
codizzl is offline   Reply With Quote
