10-23-2006, 02:02 PM | #1 |
Pebble Pounder Join Date: Feb 2006 Location: Dallas, Ga
| Which motor???
Trying to decide on a motor for current project. Between a 65t lathe and a truck puller 80t. http://www.lrp-electronic.de/e/lis/N...k-Puller-2.jpg I noticed from this post and the LRP technical data site that the 80t has an open RPM of 6500 and the 65t 6400. Does anyone have one of these motors? The rig I am building has a very high ratio in the trans so I want the slowest motor possible. I thought that 65t is as high as it went, and then I found the truck puller 80t. Any info would be appreciated. Also does anyone have any info on the 75T from integy? |
10-23-2006, 02:47 PM | #2 | |
Quarry Creeper Join Date: Feb 2006 Location: Shillington
http://www2.towerhobbies.com/cgi-bin...&I=LXSL79&P=ML | |
10-24-2006, 12:50 PM | #3 |
Dont have enough room for a gd600. Have these on order from ebay. He told me that they are 5500 rpm open at 12 volts so we will see how they perform. http://cgi.ebay.com/B-B-Motors-Axle-...QQcmdZViewItem |
10-24-2006, 06:18 PM | #4 |
That will be too slow and weak on 6-8 cells, if that is what you run. What are you putting this in? Electrics, vehicle? |
