Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: I can NOT decide on what to build
Old 01-07-2014, 12:41 PM   #1
Default I can NOT decide on what to build
OK so after having running the MJ for my son and upgrading the heck out of it (The part I most Love), I am really looking forward to a Scale build. But here is the issue.
I want a scale looking EB capable of crawling and when needed doing some good old hardcore trailing and some jumping. I'm not talking basher jumps but I want it to be serious power and ability. My 1st thought was to start with the SCX10 of some kind but then I don't know if it can handle what I'm after.
I envision a early Bronco running some 40 series Boggers with plenty of power and suspension AND looks somewhat to scale.
Thoughts?
Markeje is offline   Reply With Quote
Old 01-07-2014, 02:08 PM   #2
Default Re: I can NOT decide on what to build
I think the bronco idea is cool. I really don't know about the frame though, I would think a scx10 frame but you said it won't fit your needs.
79SCX10 is offline   Reply With Quote
Old 01-07-2014, 02:15 PM   #3
I don't know maybe it would. I've been going through all the SCX pics thread. There are several already that have some of the ideas and looks I'm after. I don't want to just crawl with it though. Around here it would be more like dirt/mud/water trail driving with the occasional jump and stuff. I'm not looking to unrealistically jump the thing but you know 2-3 feet high isn't out of the question. I know the way to go is to build 1 for each purpose but that's not happening either lol. I guess I need a rock racer but somewhat stay true to scale.
So maybe the SCX with some good drive train mods and some boggers. Plus the right electros might be what I'm after all.
Old 01-07-2014, 02:20 PM   #4
Dynamic Concepts makes a Early Bronco body for the Axial Wraith.
http://www.rccrawler.com/forum/vendo...panel-set.html
k7zpj is offline   Reply With Quote
Old 01-07-2014, 02:38 PM   #5
Wraith with SCX axles and a Dynamic Concepts EB body for the Wraith cage. Should be able to handle any kind of off road fun. I plan to build something along those lines.
2JSC is offline   Reply With Quote
Old 01-07-2014, 02:40 PM   #6
It sounds like you are looking for more of a basher then a true scaled or comp crawler, I would look into a Wraith with a EB bronco body.
THUNDER PRO is offline   Reply With Quote
Old 01-07-2014, 06:42 PM   #7
Going wraith is a great route to take. But looks wise, because of their width, your kinda rangled into a body, & the look of fenderless rigs. Cool as hell, but not really the 1st thing you'll see while flipping thru the book of scale. I like to have the option of both, the fenderless "beast"/buggy look, & a more conventional, narrower look. This is why i tend to stick to scx axles. You can runnem either way. I have rc4wd wideners on my scx axle equipped newbrite jk. Its exactly as wide as a wraith, but in 5mins, i can switch it back to scx width. Nice to have options...
jado6006 is offline   Reply With Quote
Old 01-07-2014, 07:15 PM   #8
Moderator
JatoTheRipper's Avatar
Wraith or Twin Hammers seem to be your best options. The Wraith is much larger. Or maybe a EXO buggy with Wraith axles. I believe they're called a WrEXO.
Old 01-07-2014, 07:17 PM   #9
Ya. After a lot more looking I still think I'm going SCX. I want that scale look to some degree. Plus there are thousands of options and upgrades for it. I suppose I'd be happy with a mean bronco with some 2.2 boggers, waterproof and right gearing and motor. If I want to really launch off of stuff, I can always break out the SOAD
Old 01-07-2014, 08:43 PM   #10
Check out some of the wraith ultra 4 type builds, and google images of ultra 4 racers. The wraiths can look pretty scale with that build type, unless you are more after the bronco lifted street look then stay with the scx10 frame, just my 2c.
Cheers,
Wade
Wade is offline   Reply With Quote
Old 01-08-2014, 10:25 AM   #11
Thanks Wade! I'll look into em.
Old 01-08-2014, 11:36 AM   #12
Can someone point m to the Classifieds section btw? I have star!
The Wraith with SCX axles may be pretty cool.
Old 01-08-2014, 02:02 PM   #13
SCX with a Proline Bronco body. (2.2 mudslinges would work perfect with this set-up) Mild lift, Mild Brushless, Lots of fun in the dirt, small jumps no problem. Turn carefully. With some shock tuning it wasn't bad.
Just to give you some ideas. SCX can take it.
OSRC is offline   Reply With Quote
Old 01-08-2014, 02:21 PM   #14
Ya OSRC! Awesome looking rig man. Maybe if you don't mind I could hit you up for some advice and such for my build?
Old 01-08-2014, 02:29 PM   #15
Classifieds are at the bottom of the page, if you end up where you see all the members names you've went to far. I hope that helps.
Old 01-08-2014, 03:01 PM   #16
Thanks. I couldn't find that sucker!
Old 01-08-2014, 03:14 PM   #17
Scale Detail Engineering
Did you find the classified section?
Sometimes it takes a couple days for a Mod to unlock it...
So, central Il hu? Where abouts?
We're having an event at Eclipse Hobbies in Feb.
It's in Bradley, Il... near Kankakee.
You should come out, a couple guys will be running Bronco Wraiths with SCX10 axles.... as well as every other rig you can think of!
johnnyh66 is offline   Reply With Quote
Old 01-08-2014, 05:07 PM   #18
I'm just south of Peoria.
Haven't looked on my laptop for the classifieds yet.
I'm having to check that deal out! It'd give me some ideas and information I'm sure.
Old 01-08-2014, 05:30 PM   #19
Sent from my DROID RAZR using Tapatalk 2
BMoreScale is offline   Reply With Quote
Old 01-08-2014, 08:21 PM   #20
You betcha, I'll answer whatever I can. Always glad to help a fellow Bronco fan.
I can NOT decide on what to build - Similar Threads
Cant decide on Chassis for Berg build! Ricky G EnRoute Berg 11 08-18-2013 11:26 PM
help me decide nathand Newbie General 6 01-15-2010 05:23 PM
Help me decide which build MNorby General Scale Talk 6 10-20-2008 08:14 PM
What should I build? Please help me decide! matts88yj Newbie General 11 11-26-2007 01:25 PM
