10-30-2006, 03:33 PM | #1 |
Rock Stacker Join Date: Oct 2006 Location: Raleigh
| (question) broke servo mount location on axle casing
rear tlt axle w/ rear steering. I used search first and didnt run across this issue where my servo mount attaches to the plastic pillars on the axle casing, the screws ripped out and broke a pillar(on the axle housing itself - not the the pillar for the above servo link mount) can I just JB Weld the servo mounting plate to the axle housing? I saw a vendor has some aluminum tlt axle casings coming out...should be a big help for these issues! if you have a better suggestion than the JB, I am all ears! thanks, Dave |
10-30-2006, 04:32 PM | #2 |
My understanding is that JB wont bond to plastic as well at 2 part epoxy would do you still have the broken off parts? if so just re-glue them and redrill the hole for the screw if you have to
10-30-2006, 04:43 PM | #3 |
the one pillar in question is torn apart. looks like the screw ripped out and it basically exploded. of course I have a spare for the front half of the axle housing....but need the rear lol I need a different way to mount the servo mount now. |
10-30-2006, 04:47 PM | #4 |
Is there a hole in the axle now? If not get some 1/8 id-1/4 od delrin rod grind it with a dremmel to make it look like the old piece and grind your housing to where you could reattach it using epoxy
10-30-2006, 04:52 PM | #5 |
RCC Addict Join Date: Feb 2006 Location: Medford, Oregon
May not have you back crawling this week, but it doesn't seem to be too expensive of a part. http://www2.towerhobbies.com/cgi-bin...&I=LXGHG0&P=OW |
10-30-2006, 05:39 PM | #6 |
that will work, thanks! think I will order 2 for if it happens again. plastic doesnt have the best clamping properties for screws with the stress we put on them lol. |
10-30-2006, 08:32 PM | #7 |
after looking at my setup more, i think the way my upper links are mounted are putting too much stress on the servo mount. it is acting like a lever and prying it from the axle housing. the upper links fastened flat against the mount have a little wiggle room on the bolts, but when the wheels are in motion pulling the truck, i think the upper links are not giving enough. even using a mount like my shocks have attached to the top of the mounting plate at a side angle would probably lessen the stress a bunch. I may go with a design like hulkwerks has, or just fab somethjing similar up using the axle mounting holes currently used for shock mounts. any holes in my logic? |
10-31-2006, 06:42 AM | #8 | |
Quarry Creeper Join Date: Apr 2006 Location: Cincy
10-31-2006, 03:33 PM | #9 |
the short post broke on mine. I ended up trying some jb weld I had around the house and coated everywhere the servo mount meets the axle, then screwed everything back together to set. solid as a rock today! when I relocated my upper links i wont have stress on the servo mount anymore so it will be a non issue. I ordered 2 sets of axle housings in case it happens again though. I like the hulkwerks version where the upper link mount attaches directly to the axle and is formed around the servo. I will order his or make something functionally similar out of angle iron/aluminum. |
