04-13-2014, 10:38 PM | #1 |
Newbie Join Date: Mar 2014 Location: Tustin
| Pros and cons with running 2.2s on scx10
I'm getting a scx10 dingo kit with 2.2 wheels on it guy built it and had it as a shelfer. So what are the pros and cons will I have to do any adjustments I'm gonna put my rubicon links to be able to put my shell on it but what would I need to do to make my ride good?
04-13-2014, 11:15 PM | #2 |
Quarry Creeper Join Date: Aug 2013 Location: Fort Worth
| Re: Pros and cons with running 2.2s on scx10
If the 2.2's require you to lift the body, you might find it top-heavy causing it to roll more easily. I use some smaller diameter 2.2 flat irons on one my rigs as a middle ground that doesn't require the body to be lifted.
04-13-2014, 11:25 PM | #3 |
| Well this is her in planing on mounting my jk on it and those are flat irons right? |
04-14-2014, 11:54 AM | #4 |
2.2's are all I run on everything. Are they always "scale"? Nope but wtf does that matter when they make the rig more capable? Taller tires and a decent suspension setup will beat small tires and a fantastic suspension setup more often than not. The only slight downside is you may break axles or drivelines a bit more often but thats up to your trigger finger if it happens or not.
04-14-2014, 12:38 PM | #5 |
So would the stock shocks be good or would I need to upgrade?
04-14-2014, 06:01 PM | #6 |
Rock Crawler Join Date: Oct 2006 Location: New Tripoli, PA
I think that Dingo looks pretty darn sweet
04-15-2014, 06:11 AM | #7 |
Newbie Join Date: Aug 2012 Location: nj
love it .. what tires are those ? I like how wide they are ...
04-15-2014, 06:47 AM | #8 |
Stock shocks will be good but you will need to upgrade the drive train for reliability... just lkke 1:1- lockers or spools, drive shafts, trans gears.
04-15-2014, 12:55 PM | #9 |
Yea I like the looks I haven't yet seen it in person but I bet it's gonna be sweet proline flat irons 2.2 on proline beadlocks it has read lock outs
04-15-2014, 01:40 PM | #10 |
Quarry Creeper Join Date: Feb 2012 Location: Near the IL/WI border
| Re: Pros and cons with running 2.2s on scx10 Pro-Line Flat Irons. Pro-line lists the width as 2.15 inches. (155mm)
04-15-2014, 02:10 PM | #11 |
Well I guess there 2.15 he told me they were 2.2 but if not it's still a sweet looking rig so I'm guess ice they won't rub?
Pros and cons with running 2.2s on scx10 - Similar Threads | ||||
3s pros and cons | Tcp57fd | Newbie General | 10 | 05-24-2013 10:51 PM |
SCX10 RTR plastic links versus aluminum: pros/cons | FreedomRiding | Newbie General | 9 | 06-27-2012 03:45 PM |
Pros and Cons | wardal | General Crawlers | 1 | 11-21-2011 06:20 PM |
Pros and Cons | Iberian | Newbie General | 20 | 01-13-2010 07:22 PM |
Pros and Cons of 50/50 to 60/40 | zboarder720 | Newbie General | 5 | 05-14-2006 10:13 PM |
