04-22-2014, 08:53 AM | #1 |
Newbie Join Date: Mar 2014 Location: Denver
| Downsides to cutting tires?
I just purchased an Axial Ridgecrest and a lot of posts and Axial's blogs talk about cutting the tires for more traction. I'm curious what the downsides of cutting the tires are? I assume there must be some, otherwise they'd come that way? Thanks! |
04-22-2014, 09:36 AM | #2 |
Rock Stacker Join Date: Apr 2014 Location: Greenwich
| Re: Downsides to cutting tires?
the downside is that once you cut em your stuck with em. and if your going to cut, do it a little at a time if your unsure. factory tires are also installed as an all around trail/crawl tire. some folks gear more toward crawling and cut the tires. so it's all in what you wanna do with your rig!
04-22-2014, 12:16 PM | #3 |
Quarry Creeper Join Date: Jan 2014 Location: Western Wa. Mose Capital of the World
Cutting or sipping tire's is at best SWAG engineering ( scientific wild ass guess ) unless you have had some experienced training by some one knowledgeable in this dark art. I myself have learned it the hard way as have most people. By ruining several sets of rubber . But on the plus side I gain some knowledge. That being said get off your wallet LOL and give it a try . Pick up some used tires on the website and butcher away . All you can do is learn a new craft |
04-22-2014, 01:40 PM | #4 |
Thanks for the replies! So if I want it to be more of a trail rig, it sounds like I shouldn't cut the tires? What problems does it cause for a trail oriented rig if I do cut them? |
04-22-2014, 02:28 PM | #5 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
The main reason the tires don't come cut from the factory is so there are options for people cause not everyone will want them that way... Plus the factory would have to make a new mold for a version already cut...
04-22-2014, 11:35 PM | #6 | |
| Re: Downsides to cutting tires? Quote:
(You can't mold the cuts!) The main downside of cutting (yourself) is that the tire will wear out faster. That downside is academic, since worn tires are generally better than new ones (at least for rock crawling) plus that you'll more likely get new (different) tires before the stock tires are worn in anyway. | |
04-23-2014, 11:44 AM | #7 |
Rock Stacker Join Date: Dec 2013 Location: The Woods
Depending on what tool you use and how much cutting you do, be aware of carpal tunnel. This can be a very repetitive movement. That being said the factory trepadors on my AX10 seemed to grip much better once I cut them and reversed the treads. At least on rocks and hills. It had a better bite. |
04-23-2014, 07:59 PM | #8 |
Pebble Pounder Join Date: Mar 2014 Location: brainerd
i cut my 2.2 mud slingers and i love em
Downsides to cutting tires? - Similar Threads | ||||
Downsides of running 2.2 Wheel & Tires? | robertjpjr | Newbie General | 6 | 11-15-2013 09:03 AM |
Looking at a Wraith What Are the Downsides? | Trazhcan | Axial Wraith | 30 | 08-21-2012 12:47 AM |
Major downsides to the CR-01? | kauaicuda | Tamiya CR-01 | 15 | 03-08-2010 05:59 AM |
Cutting tires | SouthernHighLife4x4 | General Crawlers | 7 | 06-14-2006 04:28 PM |
cutting tires | xzaq103 | Tires and Wheels | 1 | 11-20-2004 06:58 PM |
