05-24-2014, 03:21 AM | #1 |
Rock Stacker Join Date: May 2014 Location: Geelong
| BEC Voltage ?
Hi everyone I am following Harley's wraith guide and in it he said you should install a BEC I have watched a few video's on how to install them but I am not sure on what voltage I should set it at. I am still very new and only sort of get why i need it but have no idea what voltage to set it at. I have a CC usb programmer so I can set it to anything Any help would be great Cheer Paul |
05-24-2014, 03:44 AM | #2 |
Quarry Creeper Join Date: Aug 2012 Location: Anchorage
Will it be wired to only run your servo? - then set it for the servo operating voltage Or if it's to run the reciever- then the spec voltage for that, probably 6 volts there Mostly it depends on your setup, esc and rx and servo which way your going to want to wire it in and what voltage to set it to. So what's your setup? |
05-24-2014, 05:33 AM | #3 |
| Re: BEC Voltage ?
My setup is just a stock wraith but I think I will be replacing the servo down the track. It just going to be wired to the receiver |
05-24-2014, 09:36 AM | #4 | |
| Re: BEC Voltage ? Quote:
When you do decide to replace the servo, I would power the servo from the BEC and use the ESC's BEC to power the Rx. If still want to connect the BEC to the Rx to power it:
05-25-2014, 01:59 AM | #5 | |
05-28-2014, 08:12 PM | #6 |
Quarry Creeper Join Date: Aug 2013 Location: Fort Worth
| Re: BEC Voltage ?
The BEC usually only becomes necessary when you are running a higher torque servo. The built-in BEC in your ESC won't do well with high torque or high voltage servos. If you ultimately end up with a high voltage (usually up to 7.4v), and high torque servo, the BEC will be needed. For high voltage servos, you can directly power your servo (rather than use the BEC to power the receiver) so you can set the BEC voltage at 7.4v (for example, if your replacement servo handles that voltage) using a receiver bypass like this one: CreationFab - Plugs Other Receiver Bypass Adapter Hope that makes sense, good luck! |
05-28-2014, 09:03 PM | #7 | |
I have ordered a bypass Adapter I am going to upgrade the servo once the stock one claps out. I will install the BEC then directly to the servo like you suggest. Cheers Paul | |
05-28-2014, 09:50 PM | #8 |
Rock Crawler Join Date: Nov 2013 Location: In the country
I think i want the same? this plugs in to rx and then servo? Sent from my LG-E980 using Tapatalk |
BEC Voltage ? - Similar Threads | ||||
BEC Voltage | Orph3o | Electronics | 3 | 10-25-2012 10:53 PM |
Voltage Regulator = BEC? | chiatw73 | Newbie General | 3 | 02-25-2011 06:56 AM |
CC BEC Voltage | t-roller | Losi Mini-Rock Crawler | 10 | 10-27-2010 08:18 AM |
Voltage setting on CC bec - need help! | papabash | Electronics | 6 | 08-09-2009 05:36 AM |
