06-04-2014, 04:58 PM | #1 |
Newbie Join Date: Apr 2014 Location: Buena Vista
| motor runs backwards
I just installed a new radio and ESC in my wrath and also a new motor. My issue is that my throttle ( finger ) control is backwards . Push is forward pull is backwards . Do I just switch the motor wires around ?
06-04-2014, 05:08 PM | #2 |
| Re: motor runs backwards
The details on the radio, esc, motor and how the motor is timed would be really useful to help answer your question. If you have a Futaba radio you need to make sure the throttle is set to REV for a lot of ESCs. If the motor has 0 degree timing and if it is a brushed motor then you can just swap the wires. |
06-04-2014, 05:26 PM | #3 |
Ok it is a brushed motor with a stock ESC and a Spektrum DX3C radio and reciver
06-04-2014, 06:07 PM | #4 |
You need to recalibrate the esc to the radio. The mfg should have that info on their website or in the instruction manual. Also, make sure the motor is wired properly. |
motor runs backwards - Similar Threads | ||||
timing and running motor backwards | Hoser1869 | Electronics | 6 | 03-17-2014 06:19 PM |
Motor runs faster in reverse than forward | Fumbles | Electronics | 7 | 02-07-2014 01:58 AM |
AX-10 Motor Mounted Backwards | Rock Hound | Axial AX-10 Scorpion | 9 | 11-03-2008 01:28 PM |
Motor Runs In Reverse!!!! | STEEL_CITY_CRAWLER | Electronics | 7 | 06-18-2008 10:38 PM |
lathe motor noisey when running backwards, normal? | newth | Electronics | 2 | 11-17-2005 09:13 AM |
