07-24-2014, 02:10 PM | #1 |
Pebble Pounder Join Date: Jul 2014 Location: Oregon coast
| Noob tire question
I am running 1.9 wheels at the moment and would like a larger tire, what tires have the tallest sidewall for 1.9 wheels? or are they pretty close the same height?
07-24-2014, 02:12 PM | #2 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: Noob tire question
do you plan to raise the body or lift the truck to handle the taller tires?..servo upgrade in the front?...stronger drivetrain?..gearing changes?..do you want the truck to roll over much easier?
07-24-2014, 02:23 PM | #3 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
The new RC4WD Gladiator and Compass tires have a very tall sidewall as well as the Proline TSL SX XL. Basically, any really tall tire will have a proportional sidewall height.
07-24-2014, 03:32 PM | #4 |
| Re: Noob tire question Well I jacked my shocks up for max clearance but as we know that makes them stiffer and also gives my drive shafts a questionable angle as well so I would like to get softer play out of them by putting them back to a lower setting also giving the drive shafts a smoother angle, and then switch to a taller tire to make up for the drop. Maybe I'm wrong but I like to tinker any which way, plus I have had my eye on the TSL's for a while
07-25-2014, 05:51 PM | #5 |
Newbie Join Date: Sep 2011 Location: Murrieta
I have a set of RC4WD Mickey Thompson Baja Claw TTC's and at 4.75" tall, they are the tallest I am aware of: Sent from my iPad using Tapatalk |
07-26-2014, 11:21 AM | #6 |
Thanks Stricklin
07-26-2014, 11:31 AM | #7 |
| Re: Noob tire question Well dang I just measured my stock Pangol tires and with no weight on them they are 5" from tread top to tread top, maybe thats about as big as I will find for 1.9's?
07-26-2014, 12:48 PM | #8 |
Rock Crawler Join Date: Nov 2008 Location: Beloit,ohio
The new wildpeak m/t that come on axials g6 are also 4.75" tall but slightly narrower than the mt's
07-31-2014, 04:25 AM | #9 | |
| Re: Noob tire question Quote:
Wow, you found a taller one then. I thought the MT TTC's were the tallest 1.9's. What are "Pangol tires"? | |
07-31-2014, 04:36 AM | #10 | |
1.) Buy some lift kits that attach to your shock towers..this will allow you to keep the shocks but raise the chassis higher... or simply buy longer shocks...most like 100mm 2.) Lift the body higher using the holes on the body posts. 3.) you can correct your pinion angle by making custom length upper links..The angle really isn't that great even stock and needs improvements anyway. 4.) Get yourself a much stronger servo as you will need it to turn all that rubber. 5.) make sure you check motor temps after the change...if its getting too hot then gear down on the motor pinion gear to bring it back to normal 6.) Expect to replace a few parts as they break with the added stress on them. That's about all I can personally help you with. Enjoy. Last edited by 6sharky9; 07-31-2014 at 04:50 AM. | |
07-31-2014, 09:27 AM | #11 | |
And thanks sharky for the tips Last edited by RockBiter; 07-31-2014 at 09:30 AM. | |
08-05-2014, 11:12 AM | #12 |
No name brand or numbers on them, just generic HSP crawler tires I guess.
08-10-2014, 11:39 PM | #13 |
Newbie Join Date: Feb 2014 Location: vancouver
| Re: Noob tire question the proline tsl super swampers XL 1.9 are pretty tall.and really soft too. the are the best tire by far or the pitbull rock beasts.
Noob tire question - Similar Threads | ||||
Tire foam question. WARNING!!! Noob question! | tokdl | Tires and Wheels | 6 | 05-07-2014 10:55 AM |
Noob Tire question | crawler2.2 | Axial XR10 | 0 | 06-09-2013 03:50 PM |
Noob tire question | Bc-roush | Newbie General | 18 | 06-15-2011 04:45 PM |
noob tire question | trial boy | Newbie General | 3 | 12-17-2010 11:41 PM |
Noob question about tire foams | tunis | Newbie General | 3 | 09-21-2007 08:18 AM |
