07-27-2014, 03:28 PM | #1 |
Pebble Pounder Join Date: Jul 2014 Location: Oregon coast
| resetting steering
I have searched the site a lot trying to find an answer...my question is. My steering turns really well one direction and not so much the other, on my controller I have to turn the steering trim all the way to one side to get things to drive kinda straight. There are no turn buckles to adjust so I am wondering if I can turn all the settings on the controller to dead center and adjust the truck as well as visually possible and reset the bind or something to get things set back to center and have the full use of left and right adjustment back on my steering trim at the controller. Also another question about where the steering linkage hooks to the servo, is that shaft toothed so I can pull and turn a couple clicks in place of a turn buckle? Again its a HSP Pangolin but basically ax10 gear if that helps. Thanks again in advance for any info. |
07-27-2014, 03:40 PM | #2 |
Pebble Pounder Join Date: May 2014 Location: Williston, ND
| Re: resetting steering
Remove the servo horn from the servo. Make sure the vehicle is powered ON. ZERO (or center) the steering trim on your radio. Re-attach your servo horn so that the truck will drive straight (as straight as you can get it). Now you can set your trim on your radio so it drive perfectly straight, and you should have full throw R/L. Make sure your end points are set to the full amount (to the point of binding), and your dual rate is 100% (depending on your radio the EPA and DR may not be available to adjust)
07-27-2014, 03:50 PM | #3 |
Thanks Brain. |
07-27-2014, 10:57 PM | #4 |
You're welcome. Enjoy being able to turn both directions, lol.
07-29-2014, 08:41 PM | #5 |
Newbie Join Date: May 2014 Location: brownsburg
I was havin the same problem, thanks for the info.
resetting steering - Similar Threads | ||||
Resetting m2 dig | jrcheese | Electronics | 1 | 03-03-2011 08:48 PM |
resetting dx6 question | mattstang | Electronics | 2 | 10-23-2010 11:47 PM |
inside tyre touches steering knuckle / steering linkage | murky123 | Axial SCX-10 | 4 | 10-06-2010 04:46 PM |
Hot Racing Steering knuckles - more steering than the original plastic ones? | Tomy | Axial AX-10 Scorpion | 1 | 11-16-2008 11:26 AM |
Resetting the ESC? | TunaMaxx | Losi Mini-Rock Crawler | 5 | 09-29-2008 12:53 PM |
