08-27-2014, 07:08 PM | #1 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
| do I need CC external bec using MMP esc?
I will be running the roc412 3100kv motor and mamba max pro esc. Sometimes on 2S batteries, sometimes on 3S. The single servo I will be using is a Hitec HS-7955TG, rated .15sec/333oz at 6v. Do I need to use a 10 amp CC external bec? If so, can someone please post a diagram of how to wire everything mentioned above? If I see no diagrams, I just plan on buying this Holmes Hobbies LLC Although, I'm not quite sure where the servo end goes and where the BEC goes using that adapter. Can someone explain which plug goes to where on the adapter? Thanks in advance. |
08-27-2014, 07:48 PM | #2 |
Rock Crawler Join Date: Jan 2012 Location: middle TN
| Re: do I need CC external bec using MMP esc?
Yes you need a bec
08-27-2014, 07:56 PM | #3 |
| Re: do I need CC external bec using MMP esc? using this Holmes Hobbies LLC where does the servo plug go on the double wide end? Is it the one with the black and red wires female plug? Or, is it the black, red, and yellow female plug? |
08-27-2014, 08:37 PM | #4 |
RCC Addict Join Date: Aug 2009 Location: Earth?
| Re: do I need CC external bec using MMP esc? Yes, you need a B.E.C. |
08-27-2014, 08:38 PM | #5 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
Your looking for this |
08-27-2014, 10:46 PM | #6 |
thank you altd896...that's what I was looking for
do I need CC external bec using MMP esc? - Similar Threads | ||||
wp xl-5 esc with external bec ?? | greggreg2011 | Electronics | 4 | 09-12-2012 03:32 AM |
M2 dig esc with external BEC glitch | Elliott000 | Electronics | 8 | 07-30-2011 07:06 PM |
MMP and external BEC? | TSK | Electronics | 5 | 03-11-2011 08:54 PM |
using external BEC & esc's internal BEC.... | slowlearner | Newbie General | 2 | 02-14-2010 01:35 AM |
