09-14-2014, 02:19 PM | #1 |
Newbie Join Date: Sep 2014 Location: Gladewater
| Disappointed in the yeti
Hi, all been lurking a few weeks ,I get my new yeti in and can't get to run . I have done all the pre-flight , calibrated the esc and all I get is a little jerking when the throttle is pulled nothing in reverse. Any ideas as to what mite be my problem.
09-14-2014, 02:24 PM | #2 |
Pebble Pounder Join Date: Feb 2014 Location: gladwin
| Re: Disappointed in the yeti
You have to rebind the reciever and also check your end points Sent from my iPhone using Tapatalk |
09-14-2014, 02:34 PM | #3 |
RCC Addict Join Date: Jan 2010 Location: Vermont
Check your bullet connectors from the motor to esc and make sure they are secure.
09-14-2014, 06:48 PM | #4 |
Thanks for the replies but it is a faulty motor
09-14-2014, 07:20 PM | #5 |
I was checking out a new RTR Yeti at my LHS and when I rolled it fore and aft on the counter the transmission made an odd hollow meshing sound as it was rotated Fr/Rr... Is that normal ? |
09-16-2014, 03:15 AM | #6 |
Good news found a wire that was loose at the solder joint fixed and running |
09-16-2014, 03:31 AM | #7 |
Pebble Pounder Join Date: Mar 2011 Location: Wales,UK
| Re: Disappointed in the yeti Well one of the preflight checks is to check the spur/pinion mesh - with 48p gears it should be pretty smooth. Also note an incidence of a missing bearing in the transmission and loose driveshaft pins. Sadly these things seem to need a lot of checking over - hopefully early QC issues !
09-16-2014, 10:25 AM | #8 | |
Quarry Creeper Join Date: Mar 2013 Location: Pilipinas
| Re: Disappointed in the yeti Quote:
09-16-2014, 01:21 PM | #9 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
| Re: Disappointed in the yeti |
09-16-2014, 01:26 PM | #10 |
09-16-2014, 05:30 PM | #11 |
Disappointed in the yeti - Similar Threads | ||||
Yeti, Set, GO!!! FastEddy Bearings for the Axial Yeti | FastEddy | Axial Yeti | 13 | 04-21-2015 07:33 AM |
water yeti.. calling all yeti owners | going2fast | Axial Yeti | 11 | 11-02-2014 05:43 PM |
Disappointed :( | Fanfor88 | Axial Wraith | 46 | 12-23-2011 10:32 AM |
A Little Disappointed | twisted | Tamiya CR-01 | 8 | 11-13-2008 11:31 PM |
