Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: cms question
Old 10-21-2014, 10:44 PM   #1
Default cms question
First off I can't use the search bar gor some reason. So here is my question....Has anyone took the servo mounting plate off the axle and mounted it right onto the frame using the 3rd hole back and the front hole of the shock?
dkchance74 is offline   Reply With Quote
Old 10-22-2014, 01:15 AM   #2
Default Re: cms question
Ya , Iv'e done it a few time's , work good. Don't forget to make a panhard bar.
old man 52 is offline   Reply With Quote
Old 10-22-2014, 01:24 AM   #3
Thanks man I appreciate it. Where do you mount the panhard bar? Got any pics or a link for me?
Old 10-22-2014, 04:19 AM   #4
I have done this to a few scx10's and ran my last one for a couple of years with no bump steer problems, but have recently swapped over to a 3 link with panhard for a more scale look.
greenjk is offline   Reply With Quote
Old 10-22-2014, 02:42 PM   #5
I can't seem to get the servo set right for steering both ways
Old 10-22-2014, 03:26 PM   #6
Lentsnh2012 is offline   Reply With Quote
Old 10-22-2014, 03:30 PM   #7
I think my main problem is ive still got the cheap steering links
Old 10-22-2014, 05:48 PM   #8
FWIW, seems like a lot of effort when you can just pick up a CMS/panhard kit like the one from RC4WD. That will have everything you need (servo mounting bracket, panhard mount for chassis, panhard mount for axle, panhard link) save for the metal steering link, which you need anyway) and the geometry will be correct.
new2rocks is offline   Reply With Quote
Old 10-25-2014, 10:49 AM   #9
I tried doing the same thing a while back. only thing i did was mount servo to frame. It drove like garbage had bumpsteer like crazy and was just an overall waste of time. since then i have learned a lot about the steering geometry and how to do it right. If you enjoy building things and doing it on your own then go for it. thats the best thing about these trucks. Although there is bolt on options available if you just want to get it done quickly.
yotapower07 is offline   Reply With Quote
Old 10-30-2014, 04:34 PM   #10
Has anyone used the tamiya tlt stays as panhard mounts?
Old 10-30-2014, 04:39 PM   #11
I don't see why you couldn't.
Old 10-30-2014, 04:43 PM   #12
Ya the one with two holes
Old 10-30-2014, 04:44 PM   #13
Got any pics for reference?
Old 10-30-2014, 05:03 PM   #14
Same cut as what's shown in post #50, but instead, braze/weld to your frame. Done.
XSRCdesign's RC4WD Scaler Build off entry "Silverado Truggy"
Old 10-30-2014, 06:31 PM   #15
tlt stays make perfect panhard mount have used many for that application
joshsmith512 is offline   Reply With Quote
Old 11-02-2014, 01:22 PM   #16
Here ya go .
Old 11-02-2014, 01:51 PM   #17
Moderator
badhoopty's Avatar
yep. they work great.
badhoopty is offline   Reply With Quote
Old 11-02-2014, 04:25 PM   #18
This is what I've done but I can't get the servo set right
Old 11-02-2014, 07:11 PM   #19
Did you center all your trim button before putting on the servo horn?
Old 11-02-2014, 09:09 PM   #20
Moderator
badhoopty's Avatar
if the phb is hitting the bottom of the servo at compression, put some spacers between the servo mount and servo toward the back.
cms question - Similar Threads
CMS question kincer Axial SCX-10 5 09-17-2013 07:08 AM
CMS question jeepscx10 Newbie General 5 03-08-2013 12:27 PM
3 link cms question wingnutcrawler General Scale Talk 14 04-01-2012 01:52 AM
CMS Question alexchen86 Electronics 6 07-15-2011 03:36 PM
question about cms toka100 Axial SCX-10 4 04-04-2011 07:44 PM
