03-04-2022, 09:35 PM | #1 |
Newbie Join Date: Mar 2022 Location: Chicago Metro
| Micro comp brushless (Newbie to crawling)
I am new to crawling, and am completely enamored of this (scratch built?) Micro comp brushless vid on YouTube: https://www.youtube.com/watch?v=ma1gMVBeGXc I have a ton of questions but will start with just the basics. I appreciate your help. My intended use initially is to amuse my Labrador and putz around in my garden. I find only the Bully 2 available commercially. Is the RTR for $600 a good starting point rather than scratch building? The crawler in the vid seemed quite a bit less complex mechanically than the Bully. Is there much science in how the struts are arranged? What differences will brushless have, aside from cost? Is there a difference in driving technique? (Edit: He is using sensorless motors. Is this common for crawlers? I would have thought sensored is a requirement for high torque starts from dead stop.) Last, will it be possible to climb interior carpeted stairs with a crawler? Thanks. Mike. Last edited by MikeWhy; 03-04-2022 at 09:45 PM. |
03-05-2022, 07:19 AM | #2 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: Micro comp brushless (Newbie to crawling)
Not exactly scratch built. That's using Rocksta basher axles which come with brushed motors. Look for the one that comes with metal gears in the axles rather than plastic. The frame may be custom, but there are similar 3D printed versions available on Shapeways. For the needs you've described you won't need brushless at all. You can build something capable relatively cheaply Sent from my Pixel 3 XL using Tapatalk |
03-06-2022, 09:13 AM | #3 |
| Re: Micro comp brushless (Newbie to crawling) Thanks! The RockSta seems to be unobtainium at the moment. Is it worth the wait, over something like the DasHex Z2 at AliExpress for example? The biggest relevant difference being 4WS on the RockSta. Is this something that's important? Or is it just a gimmick?
Tags |
brushless, bully 2, newbie, scratch build |
Micro comp brushless (Newbie to crawling) - Similar Threads | ||||
Best brushless vs Best Brushed setup for comp crawling - money is no object | quark | Newbie General | 25 | 08-17-2019 07:33 PM |
NEW Indoor Micro Comp Crawling | bimmerben | Iowa | 0 | 01-07-2016 06:37 PM |
NEW Indoor Micro Comp Crawling | bimmerben | Illinois | 0 | 01-07-2016 06:35 PM |
