Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Yeti Kit motor/esc combo's.
Old 02-04-2015, 08:19 PM   #1
Default Yeti Kit motor/esc combo's.
So..after many hours of searching here and google, I am still a little lost on motor and esc combos for my Yeti Kit.
From what I have found on here, MMP/RX8 with a Pro4HD motor are just about what everyone runs. But most that are running those are doing that for the sensored operation at low speeds for crawling/U4 events.
The Yeti I have will more than likely never be a crawler, I have my scx10's for that, and where I live, there are no U4 events. It will be a basher.
Is a sensored setup necessary for a basher?
I already know people have thermal issues with the stock Vanguard setup, so I know I will have to get something bigger...But how big is to big before I just start destroying things all the time.
Thanks for any advice...
Perkul8r is offline   Reply With Quote
Old 02-05-2015, 05:06 AM   #2
Default Re: Yeti Kit motor/esc combo's.
Sensored is not required for bashing.
If you're on a budget. Get a hobbywing 80 or 120A sensorless esc and run whatever you want for a motor up to 4 or 6s lipo
dna4engr is offline   Reply With Quote
Old 02-05-2015, 07:42 AM   #3
Budget isn't really an issue. I have been looking at the hobbywing Esc, just nobody local has one. The place I am getting my kit from has a lot of esc/motor options. Mainly Tekin, Castle, Viper, and Reedy motors.
I have been looking at the castle Sidewinder 8th, but haven't seen anybody run a 2200kv motor in the Yeti. I know they are stock in the the Yeti XL, but thats a bigger/heavier rig.
Old 02-05-2015, 08:44 AM   #4
I've been running a viper vst 4.5xl motor and a vtx8 esc and it does pretty good at slow speeds. Also it goes way to fast for the stock yeti.
kind325 is offline   Reply With Quote
Old 02-05-2015, 06:52 PM   #5
I was looking at the Viper stuff...but out of stock where I am going this weekend. lol.
I have been looking at a lot things, I may just bite the bullet and go with the MMP and Pro4hd. But I see alot of people are using the 3000kv and only the 3500kv is in stock where I go. Not sure how much of a difference that makes.
Sucks I would have to take things apart too to waterproof everything.
Old 03-29-2016, 02:59 PM   #6
What gearing?
jreckner is offline   Reply With Quote
Old 03-29-2016, 03:02 PM   #7
Originally Posted by jreckner View Post
What gearing?
It's been a long time since I ran my yeti as I tore it down to upgrade my bomber... But I know the spur was a 68 and I'm guessing the pinion was a 15. Stock gears in the diffs.
Old 03-31-2016, 08:24 AM   #8
I will be running a hobbywing sc8 and neu-castle 2650kv
WrMarine is offline   Reply With Quote
Old 04-03-2016, 06:33 PM   #9
MMX & Holmes Hobbies Puller Pro BL 540 XL 3500kv.
Does perfect rolling backflips with stock gearing
Tyr-Sog is offline   Reply With Quote
Yeti Kit motor/esc combo's. - Similar Threads
New Kit Yeti what motor/ ESC???? mtnbker Axial Yeti 30 02-06-2016 02:29 AM
Rock Force Kit Combo's? Bart bender Kyosho Crawlers 3 12-26-2008 06:28 AM
