12-14-2006, 12:31 PM | #1 |
Rock Crawler Join Date: Nov 2005 Location: Oak Ridge
| Winch Wiring
I am using an old 645MG to create a winch. The circuit board is fried, but the motor still operates fine. I would like to run the servo off the main battery, if possible. I'm looking for a switch to reverse the polarity so I can spool the line out, as well as reel it in. Will this switch work? http://www.radioshack.com/product/in...entPage=family I will most likely be using a cheap plastic gear servo to throw the switch, to operate the winch. I guess I could also use a small ESC. Will ESCs work with the non-proportional switches for the 3rd channel? Any reccomendations on a small (cheap) ESC that will work in this application? |
12-14-2006, 04:24 PM | #2 |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
I would get the black one.Its a momentary 6 prong switch.That way it's not locked into one direction.Just tap it in either direction and it will run.Hope that helped!?
12-14-2006, 04:39 PM | #3 |
Thanks for the response! Is this the switch you are referring to? http://www.radioshack.com/product/in...entPage=family The third channel on my radio (TQ3) has no EPAs. Do you think the throw of a standard servo is pretty close to the throw needed to activate the switch? |
