03-10-2015, 02:46 PM | #1 |
Newbie Join Date: Mar 2015 Location: northwest
| Bent lower links
Just wondering what the advantage or disadvantage of longer or shorter bent lower links.
03-11-2015, 01:47 AM | #2 |
Pebble Pounder Join Date: Feb 2015 Location: Mount Morris
| Re: Bent lower links
Bent lower links give more ground clearance to get over bigger rocks. Shorter lower links will shorten the wheel base and make the truck taller while longer do the opposite.
03-11-2015, 05:01 PM | #3 |
Newbie Join Date: May 2013 Location: Cleveland
depends on the rig on a scaler i would stay away from bent lower links just because straight lowers will protect your drive shaft but on a comp rig i would def run bent links
Bent lower links - Similar Threads | ||||
Lower Bent Links ? | Briguy-01 | Axial SCX-10 | 3 | 04-18-2013 04:11 PM |
bent lower links | ped453 | Losi Mini-Rock Crawler | 4 | 05-03-2010 05:14 PM |
Bent Lower Links for a 1.9 | SSOOCH | Newbie General | 1 | 04-21-2009 03:14 PM |
Bent lower links ? | Joat | Tamiya CR-01 | 3 | 09-17-2008 12:15 AM |
