Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Installed asiatees c hubs, now my camber is negative?
Old 03-12-2015, 11:01 AM   #1
Default Installed asiatees c hubs, now my camber is negative?
After installing these parts: GPM Racing Axial SCX10 Aluminum Front C-Hub & Knuckle Arm (Toe-In 5 Degree) - 4Pcs Set Black SCX019+021/5D
Is there a purpose for this angle? Or did I install it wrong? It looks wrong when I'm driving it around, but the hubs were marked R and L so I'm pretty sure I have them on the correct side.
Also, is there a metal replacement for the plastic gears in the transmission? Part# ax80010
Thanks for helping a newbie . This place has been an excellent resource.
woodsman541 is offline   Reply With Quote
Old 03-12-2015, 11:30 AM   #2
Default Re: Installed asiatees c hubs, now my camber is negative?
Yeah that's really weird. Looks like you have a ton of negative camber:
Not Toe
Looking at the pictures on the website it looks like these are designed that way, sometimes the Chinese companies do weird stuff like this imitating better parts. All of the knuckles and C's from vanquish are "8-degree" in that the axis the knuckle turns on is tilted 8 degrees to reduce scrub, however the plane of the wheel / tire remains vertical. It looks like GPM attempted to do something similar but just half-assed it and only changed the C. It looks like the knuckles are pretty standard issue, so if you want to get it back to normal I'd pick these up:
*RCP*Crawlers*AX10*SCX10*2...
Or these:
STRC ALUM HUB CARRIERS SCX10 (2) BLACK
But I'd make sure those knuckles fit on the stock C-hubs first just to be sure.
For your transmission gears use these:
Hot Racing Axial SCX10 AX10 Wraith hard steel center gears set
Highmark is offline   Reply With Quote
Old 03-12-2015, 11:31 AM   #3
MODERATOR™
EeePee's Avatar
"GPM has announced to release the anodized optional toe in 5 degree c-hub, knuckle arm and turnbuckle for the SCX10"
Got to be their version of the 8 degree kingpin inclination set up and they don't know how to word it.
Which also means you have it on upside down.
EeePee is offline   Reply With Quote
Old 03-12-2015, 11:42 AM   #4
Wow thanks guys! So happy I got a response!
Old 03-12-2015, 11:46 AM   #5
Scale Detail Engineering
yup, my first thought... upside down. (been there, done that. )
johnnyh66 is offline   Reply With Quote
Old 03-12-2015, 11:50 AM   #6
I didn't even think about them being upside down.
Old 03-12-2015, 11:51 AM   #7
I've had that same issue happen before too! Once I flipped mine the rightside up, it fixed the issue
Loverslie is offline   Reply With Quote
Old 03-12-2015, 11:55 AM   #8
MODERATOR™
EeePee's Avatar
That Texas water is already getting to ya...
Old 03-12-2015, 12:17 PM   #9
I did consider they might be upside down but I assumed if I flipped them I would just end up with positive camber. Can't wait to tear it down tonight and see if that fixes it.
Old 03-12-2015, 12:40 PM   #10
Your tires are on backwards too. Do you have them on L and R looking at the truck or as if you're sitting in the truck?
Here's Axial metal transmission gears --
Axial Racing - AX10 Locked Transmission - Complete Metal Gear Set - Steel (3pcs)
GodSpeed999 is offline   Reply With Quote
Old 03-12-2015, 12:43 PM   #11
The C-hubs have a kingpin angle. To have zero camber angle the knuckles have to create the same angle, just in the opposite direction. My guess is Post a pic of your hub without the wheel so that we can see.
Odd-M is offline   Reply With Quote
Old 03-12-2015, 01:03 PM   #12
Wow, my tires are on backwards. Glad I'm in the newbie forum!
Old 03-12-2015, 01:09 PM   #13
Originally Posted by GodSpeed999;5172903Do you have them on L and R [I
looking at[/I] the truck or as if you're sitting in
I don't remember, which one should it be?
Old 03-12-2015, 01:12 PM   #14
the "V" should be pointing forward (or down in the pic)
Old 03-12-2015, 03:31 PM   #15
Whenever you're talking about Left and Right of a vehicle, always picture/position yourself inside or behind, not looking at it from the front.
You don't have to peel your tires off the rims and reverse them; just switch sides.
I was curious because you mentioned the chubs say L and R on them but if you were looking at the front of the vehicle when determining which side to put them on, you may have reversed them.
I still honestly don't see how that will resolve your weird camber issue. Left and Right for chubs doesn't normally matter, actually. In your case, upside down would, but I would imagine that would just create positive camber.
Left and Right would matter for toe, but you have camber, not toe. Strange.
Old 03-12-2015, 03:54 PM   #16
The c hubs have a definite angle to them even when not mounted, it was intentionally manufactured that way, though I have no idea why. When I get home tonight I will tear it apart and see what I can do, if flipping them doesn't help I will take more detailed pictures. Thanks!
Old 03-12-2015, 04:54 PM   #17
Take pictures for us with the wheels off and chubs still installed and then some pics of the chubs themselves.
Old 03-12-2015, 09:57 PM   #18
You win! The hubs were on correctly but the knuckles had a corrective counter angle that i didn't see when i was assembling it the first time. I'm all straight now, thanks everybody!
Old 03-13-2015, 07:17 AM   #19
Could just be the picture, but now it looks toe out.
Installed asiatees c hubs, now my camber is negative? - Similar Threads
AsiaTees Crawler... Szczerba General Crawlers 20 04-17-2014 03:56 PM
Project AsiaTees Hobby palvey83 1.9 Scale Rigs 10 09-17-2013 09:53 AM
asiatees mitchr97 General Crawlers 2 01-09-2013 04:02 PM
Asiatees Hobbies...Anyone used them? T I N Y Axial Wraith 44 11-07-2012 05:24 PM
Rear negative camber? frdtrkguy General Crawlers 1 12-30-2007 09:30 AM
