Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: Long time rcer,new to crawling
Old 12-14-2006, 09:57 PM   #1
Default Long time rcer,new to crawling
first off i started out with a nylint1:6 and now am in the process of building my first "real" rc crawler. i purchaced a TLT-1 after alot of research, and thought hmm best babg for the buck, now for my questions... 1st is there a best way to set up a 4-link? so far i am following the rccaraction write up www.rccaraction.com/online_ex/tltrockclimber.asp and it seams to be o.k. any thoughts?
tltrocker is offline   Reply With Quote
Old 12-14-2006, 10:12 PM   #2
sleek6mt's Avatar
this is better
http://www.orcrc.com/tech.htm
sleek6mt is offline   Reply With Quote
Old 12-14-2006, 10:22 PM   #3
Team Nylint
redbaron's Avatar
Originally Posted by sleek6mt
This is a much better article than the one at www.rccaraction.com. I had both of these when I built my crawler, and I ended up just using the one from www.orcrc.com.
Just follow the article, its not hard to do.
redbaron is offline   Reply With Quote
Old 12-14-2006, 10:26 PM   #4
2006 2.2 National Champ
BENDER's Avatar
Here's another option.
FAQ: TLT-1 to TLT-Crawler ***NEWBIES READ!!!***
BENDER is offline   Reply With Quote
Old 12-14-2006, 10:49 PM   #5
cblake187's Avatar
I would listen to bender even though I'm not building an sw2 don't think I did'nt read his threads!
cblake187 is offline   Reply With Quote
Old 12-15-2006, 02:01 PM   #6
Question
I started out the same way with the 1:6 Nylint. Massive power/poor ground clearance. I started out with the rccaraction build and quickly found a lot of short comings. Poor ground clearance Stock tranny :-x and poor articulation. I got another set of stock chassis plates (ebay $4), and used the two plates with the rectangular cutout. I ended up cutting the bottom portion of the stock chassis just under the upper link location. Moving lower links up to there and moving the upper links to the rear battery plate mounting hole. I also drilled new holes for mounting the shocks (T-maxx 3.3) 1/2 inch to the out side of the rear bat/esc holes. Lastly I cut one side of the stock chassis plate to allow for horizontal mounting of my Traxxas Xl-5 tranny (1/2" alum spacers on either side for centering). This thing climbs vertically now. I also added 3ox of weight to each front tire. Just a thought.
DRCMAN is offline   Reply With Quote
