Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: Mamba VMG
Old 12-15-2006, 05:32 PM   #1
Question Mamba VMG
im thinking of getting a mini giant, and use a mamba performance package with GWS gear reductor,
any advice, is this plausable? anyone tried this?
also, do you need another front axle for 4ws?
Thanks in advance
Techball is offline   Reply With Quote
Old 12-15-2006, 05:59 PM   #2
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
The mamba wont start up when bound. Once it is rolling though everthing would be all good and you will break stuff. I would recommend using a small outrunner, like a park 250 sized dealy.
If you can be easy on the throttle finger I say go for it. You will need two front axles for 4ws.
JohnRobHolmes is offline   Reply With Quote
Old 12-15-2006, 06:03 PM   #3
K_B
I shoehorned a Park 370 outrunner / Mamba-25 combo in mine with no gear reduction. It's overkill, I know, but I didn't know any better at the time. It was surprisingly easy to modify the motor plate to fit it. It's a fun little truck. But without the reduction, low end throttle response is less than ideal. I am trying to avoid having to use a bulky reduction unit so I'm experimenting with throttle curves or maybe using a Quark 33a ESC instead. The plus side is that I have LOTS of wheelspeed if I need it...
K_B is offline   Reply With Quote
Old 12-16-2006, 01:54 AM   #4
the mamba motor binds? even with a 5.33:1 reduction? uhmmm.... i just want to use brushless, should i just get another motor and sell the mamba motor?
i want to replace the clod as im going to school and want something smaller and more portable
Old 12-16-2006, 02:05 AM   #5
outrunner, eh,
i need something small
http://cgi.ebay.ca/New-Outrunner-Bru...QQcmdZViewItem
would this do? can just hook this up to the mamba-25 esc?
man im excited to build my first brushless mini crawler!
Thanks TO all the helper on this broad
Old 12-16-2006, 08:20 AM   #6
All two pole inrunners stall when bound. They just cant start up.
That motor would work, but it will be pretty fast for a vmg crawler.
