Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: My SCX10
Old 04-06-2015, 07:07 AM   #1
Default My SCX10
Hy
I will show you my SCX10 that I bought second hand.
It is a SCX10 Jeep Wrangler Unlimited C/R Edition with following Parts
Elektronik:
Motor: Team Novak Terra Claw Crawling Motor 35T
ESC: Axial AE-3 Vanguard ESC waterproof
BEC: Castle BEC Pro
Servo: Team Orion Vortex Digital Servo
Extra Parts:
Vanquish Alu Axle rear and front
Vanquish Alu C-Hubs
Vanquish Alu Steering Knuckles
Axial Alu Linkage Kit
Axial Alu Steering Mod.
RC4WD Steel Drive Shaft
RC4WD Steel Front Bumper
RC4WD Steel Side Bumper
RC4WD LED Squadron Pro LED
RC4WD Rebuildable Super Punisher Shaft
RC4WD LED small
RC4WD Interco IROK 1.9" Tires
Gear Head Waterproof LED Light Bar
RC4WD STEERING STABILIZER 90MM-120MM
RC4WD Super Punisher Shaft
RC4WD ARB Winch Snatch Block
RC4WD Warn Winch 9.5cti, 1/10
cocoda74 is offline   Reply With Quote
Old 04-06-2015, 02:08 PM   #2
Default Re: My SCX10
Hy
I need new shocks for the scx10.
is it worth to buy shocks with piggyback?
which shocks (with or without) piggyback can you recommend?
Old 04-06-2015, 04:43 PM   #3
Originally Posted by cocoda74 View Post
Hy
I'm in the same boat.... Just want to follow this thread to see what are some great options.
Thanks. ;)
ROGI77 is offline   Reply With Quote
Old 04-06-2015, 06:47 PM   #4
Default My SCX10
On most all of the piggyback shocks, the piggyback is for looks only (it doesn't do anything). The one exception I know of is the Gmade xD Piggyback, which has a functioning piggyback reservoir with adjustable oil pressure. That happens to be a good shock, and the adjustable oil pressure gives another option for tuning the shocks. But there are lots of other good options without functioning piggybacks. The RC4WD King line of shocks are very good, as are the Losi Night Crawlers, Proline Scalers, and Axial Icons. You'll get almost as many different opinions as there are shocks.
I would suggest reading up on various build threads to get some ideas of what people like on their rigs and go from there. If there are some people in your area that you can go crawling with, that's another great way to see different shocks in action. Good luck!
new2rocks is offline   Reply With Quote
Old 10-22-2021, 02:09 AM   #5
Hallo
So, i wasn't hear a long time. Time to show some updates.
ESC: Servonaut T20 (Special ESC for Trial Trucks.
Motor: Holmes Hobbies CrawlMaster Pro 540 20T/1500Kv
Shocks: RC4WD King Off Road Dual Shocks 100mm
Transmission: RC4WD AX2
Lights: RC4WD Squadron lights, GT Power High Power LED Headlight System and other lot of small led's
Chassis: SCX10 Arches
Electronics: FrSky Horus X10/S Express, Frsky Lipo voltage sensor,
FrSky FAS40S (Current sensor),Frysky GPS SENSOR, Frsky Neuron 8A SBEC
Here are some impressions: https://youtu.be/2vNp4fk14Fc https://youtu.be/2vNp4fk14Fc
https://youtu.be/ddqwwLo40b4
https://youtu.be/sm8vk6hWK_s
https://youtu.be/0M4iH7q-2Tc
https://youtu.be/ogvFm9oEalE
https://youtu.be/LD6JOWSnSxU
Automatic level regulation is is no longer installed
Old 10-22-2021, 11:19 AM   #6
Tire-Wheel Set
- Gear Head RC 1.9 RubiComp Beadlock Wheels
- Team OTTSIX Voodoo 1.9 KLR Silver Compound
- LaserFoam 1.9 R116x40 Heavy Duty
Old 10-22-2021, 12:06 PM   #7
How is the steering servo mounted in there, and how difficult is it to get out.
Greatscott is offline   Reply With Quote
Old 10-22-2021, 02:48 PM   #8
Hi
It's mounted on the axle.
This thing which is mounted on the axle is the elektronic for the winch.
See pictures
My SCX10 - Similar Threads
Need width of scx10 axles with 650 SLW hubs and/or 750? Pondering wraith vs scx10. Desert Rc General Scale Talk 6 06-25-2012 05:28 PM
