40 series tire on clod axle??? what would you need to put 40 series moab tires on clodbuster axles??? |
bender's wheel adapters"thumbsup" |
or these and some inet wideners: http://www.hot-racing.com/index.cgi?...r=CB23M08&c=38 works pefect. |
thanks alot guys |
I think that jesse(knok2222) is also having to find some for his new wheels. |
Go with Junfac adapters ($12 for 2 shipped) and some 40 series wheels with 14mm hexes. |
If you are planning on 14mm (Maxx sized hex) wheels, you need a 12mm to 14mm hex adapter / widner. There are several available, personally I run the aluminum ones from Ace, a vendor on this site. If you want to use the 23mm hex, you need to run a 12mm to 23mm adapter, which I know you can get from rd4wd, and I think from Bender. Either way, make sure you use something that spaces the wheels out far enough to clear your links. Even with the 3/4" Ace adapters, they wouldn't fit on my rig until I narrowed the inner bead. No big deal, because I was gonna do that anyways, but you should be aware of it. |
does anyone have the link to instructions on how to narrow wheels? |
