04-14-2015, 09:05 PM | #1 |
Newbie Join Date: Apr 2015 Location: Sacramento
| Newbie Wanting Advice for Vaterra Twin Hammers Kit
Edit: I went the Newbie Forum route, because that's what I am. If this would be more appropriate in the VTH specific forum, I apologize. Hello RCCrawler! My friends seem to have drawn me into this hobby. One owns three Axial vehicles, the SCX10, the Wraith, and the Exo. The other owns a Yeti. When I was contemplating which car to get, I settled on a Vaterra Twin Hammers Kit, as the title suggests. These are the electronics that I've settled on, so far. Motor & ESC: RC Gear Shop Motor System I stumbled on this brand after reading a BigSuidRC review on a 4550kV setup. I chose to go with the 3900kV version of the combo because I want the option of using a 3s LiPo battery later on, should I so choose. Also, the servo, I've found, is likely a Hobbywing, rebranded, and I like the programming capabilities offered. Of course, alternative suggestions are always welcome. Radio Transmitter/Receiver: Spektrum DX4C w/ SR410 I really liked the digital LDC display. I had read that the original radio supplied with the VTH RTR had top adjustment knobs that often got bumped or moved in transport or storage. This radio seems to have none of those drawbacks. Steering Servo: Hitec HS-646WP or Spektrum A6150 Shifting Servo: Hitec HS-5245MG Originally I was going to get a HS-225MG for the shifting servo, as it's a drop-in replacement, but because of the radio set I'm getting, the receiver requires all of the servos to be digital. Ergo, the HS-5245MG. I also plan on replacing the cantilevered shocks with and upright mod. The only two I found are BMRC and GCM Racing. I've heard that a couple people active on the RCCrawler Forums do make custom options, such as Derwood -- However, Derwood Designs is no longer producing, so that isn't viable. Does anyone know of any other options? I do like how both the BMRC and the GCM design allow for replacing the sloppy stock steering with bellcrank steering, which I also plan on outfitting on my kit. I've read that the Traxxis bellcrank steering is somewhat iffy, so I was wondering what viable aftermarket options are. I'm welcome to feedback and suggestions. Thank you! MrFoxwind Last edited by MrFoxwind; 04-15-2015 at 09:00 PM. Reason: Fixing typo. |
04-15-2015, 11:22 AM | #2 |
Quarry Creeper Join Date: Nov 2005 Location: The Great White North
| Re: Newbie Wanting Advice for Vaterra Twin Hammers Kit
The only thing I notice right off the bat, is that while it looks like the ESC is sensored, the motor is not. So low speed crawling will be marginal with that ESC / motor combo.
04-15-2015, 06:20 PM | #3 | |
| Re: Newbie Wanting Advice for Vaterra Twin Hammers Kit Quote:
Thank you, however, for your input. Edit: So, I just came back from my friends place, and we both came to the conclusion that I don't want the SRS4210 for the Twin Hammers. I plan on making a lot of use out of the 2-speed transmission, and with the AVC enabled, it takes up all four channels. Instead I'll get the Spektrum DX4C w/ SR410. Last edited by MrFoxwind; 04-15-2015 at 08:58 PM. Reason: Extra information | |
04-19-2015, 07:25 AM | #4 |
I've been hamering on my TH for about 6 monthes now. The only really good bellcrank kit, IMO, is the St. Erie. He also offers an upright shock conversion. They are produced in low quantity batches, so if you want one send him a PM and get on the waiting list. I had to wait about a month for mine. Well worth the wait since the stock sliding rack is the only real design flaw of the platform. It is somehow super sloppy, and still binds badly at the same time. The St. Erie rack is as close to zero slop as you can get, very smooth, and actually allows you to control the truck at higher speeds without the tires flopping all around. If you plan on doing an real crawling you'll want a sensored motor. I know they are more money, but you just can't get your creep on with a sensorless motor. Your going to want a stonger steering servo. Since the TH has no servo saver, and it going decently fast enough, your going to quickly destroy the gears in that Hitec servo. I'm running a Hitec 7950 and I've still broken it twice. Try to pick something with at least 300 oz/in and it will last much longer. Almost any mini servo with 40+oz/in is plenty to shift the two speed. Make sure you polish the "shift shaft" with emory cloth where it goes through the transmission case so that it will shift smoothly. |
04-21-2015, 08:40 PM | #5 | |||
Will do, thanks. | |||
Newbie Wanting Advice for Vaterra Twin Hammers Kit - Similar Threads | ||||
New Vaterra Twin Hammers KIT | Lentsnh2012 | Vaterra Twin Hammers | 27 | 04-10-2015 10:34 PM |
Vaterra twin hammers kit vs axial wraith | Mikael | General Crawlers | 33 | 02-26-2015 03:08 PM |
Electronics for vaterra twin hammers kit? | Mikael | Vaterra Twin Hammers | 9 | 11-16-2014 08:23 PM |
LetsGoMuddin's Vaterra Twin Hammers Kit | LetsGoMuddin | Vaterra Twin Hammers | 12 | 09-03-2014 03:35 PM |
