Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: What to use for a ExoSkeleton
Old 12-17-2006, 12:16 PM   #1
Your axles are Puny!
dezrik's Avatar
Default What to use for a ExoSkeleton
I have a Dodge 1/10 Body, im building a Exoskeleton for the body, im using Pede Tranny, Masher2ks, 4 link setup what kid of rod do i need that will hold up to some abuse but not add alot of weight
dezrik is offline   Reply With Quote
Old 12-17-2006, 01:16 PM   #2
From what i have seen,brake tubing should hold up fine.
Without adding to much weight.
zukifreak is offline   Reply With Quote
Old 12-17-2006, 01:38 PM   #3
I'm a stupid C U N T!
slobin3d's Avatar
for the weight of a tlt truck, brake line would be fine, but it you feel you need to strengthen parts you can run a peice of solid rod where you feel its needed. and still come out pretty light.
slobin3d is offline   Reply With Quote
Old 12-17-2006, 01:41 PM   #4
whatever!
MOCRAWLER's Avatar
for the first exo that i made. i used solid rod. it was just easier to use for the first time. i have since used brake tubing ,lots lighter. i still like the solid rod exo better though. i was able to get some better tighter bends with the solid rod. i need to get a different type of tubing bender.
MOCRAWLER is offline   Reply With Quote
Old 12-17-2006, 04:18 PM   #5
dezrik's Avatar
What Size Brakeline?
Old 12-17-2006, 04:23 PM   #6
Release your anger..
ThinkTank's Avatar
1/4 brakeline
ThinkTank is offline   Reply With Quote
Old 12-17-2006, 05:50 PM   #7
For an exo, I'd go with 3/16th and not 1/4. Saves you more weight and it really does hold up just fine to abuse.
Cloak is offline   Reply With Quote
Old 12-17-2006, 10:45 PM   #8
dezrik's Avatar
hHow much is 3/16" brakeline about 30ft how much would this be?
Old 12-17-2006, 10:48 PM   #9
You should be able to get it at your local auto parts store fairly cheap (not sure of exact $$$ though).
- Chris
Gimpy00Wang is offline   Reply With Quote
Old 12-18-2006, 02:34 AM   #10
Go with Balsa..........you won't be dissapointed. Balsa.
DrexeL is offline   Reply With Quote
Old 12-18-2006, 03:01 AM   #11
MWRCA'er
Mnster's Avatar
3/16 brake line is amazingly strong when brazed together properly.
Mnster is offline   Reply With Quote
Old 12-19-2006, 08:04 AM   #12
Manwhalo's Avatar
I think I paid around $2 a foot for 3/16" at my local auto parts store.
Manwhalo is offline   Reply With Quote
Old 12-19-2006, 09:12 AM   #13
Powered by Awesome
TwistedXT's Avatar
checker auto parts.. i get the 3/16's for about 5 bucks for a 6 foot piece. The smaller stuff is plenty strong for an exo and looks more scale. On a scale tuber im working on i use the 1/4 for the main structure and 3/16 for the detail and braces. If you want to braze it together, lowes has brazing rod for a really good price and the tube they come in is FULL! Home depot has the same rod and the tub only had like 5 sticks in it where as the lowes tube had like 15-20!!! Mapp gas it and you'll be set.... (A vise comes in really handy since your heating the metal to like 1200 degrees!) I also keep a cooler full of water right there so when you are done you can grab your work and cool it down so you can keep going!!!
Happy brazing!
TwistedXT is online now   Reply With Quote
Old 12-19-2006, 09:28 AM   #14
dezrik's Avatar
Thanks Guys, Starting my Build After Xmas Heres my Build Up post
http://www.rccrawler.com/forum/showt...494#post517494
