| | #1 |
| Newbie Join Date: Dec 2006 Location: Peoria
| I'm having trouble mounting a '06 pede tranny in a sw2.... the gear cover is in the way. Do you have to run it without the gear cover? How do you mount the transmission? Just run screws into the plastic where the original hinge pins went? Use really long bolts w/ nuts on the other end? Just curious how the experienced folks handle this simple task. |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Dec 2004 Location: HELL.....
| ya u need to ditch the gear cover, then run the screws into the hingepin holes |
| | #3 |
| 2006 2.2 National Champ ![]() Join Date: Dec 2004 Location: Driving my R/C rototiller
| You can use the two 6-32 screws, and washers, supplied with the chassis to attach the tranny to the engraved chassis plate. |
| | #4 |
| Thanks for the input guys |
| | #5 |
| Jeepaholic ![]() Join Date: Dec 2006 Location: Where the sheep run scared.
| I use a few of the brass bushings from the tlt kit between the SW2 and the tranny to better line up the drive shafts. |
| | #6 |
| Rock Stacker Join Date: Oct 2006 Location: Knoxville
| | #7 |
| Thanks for the reference - I bought my SW2 used and didn't have the washers. The marks on the chassis looks like the last guy used the washers on the outside (w/ the etching). Another question now that I see the picture. Looks like you don't run capacitors on the motor. I'm putting in a Rebel2 ESC and the mfg suggested caps. Any issues by not installing them? |
| | #8 |
| You should be able to find some #6 flat washers are your local hardware store or hobby shop for cheap. Caps on the motor will help prevent glitching. It's not mandatory to install them though. Try your rig out, if it gitches alot, installing the caps on the motor will help. |
| | #9 | |
I haven't progressed far enough to start putting my electronics together so that is why you don't see caps on there. My buddy has the same setup and his glitches so I'll probably be putting them on there. | |
| Thread Tools | |
| Display Modes | |
