| | #1 |
| Newbie Join Date: Nov 2006 Location: San Mateo
| do integy 55 turn lathe motors require any compactors??????? |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Dec 2006 Location: nampa
| i dont understand why do you need capasitors on your motors anyways integy also has 75 turn motors out also |
| | #3 |
| Rock Crawler Join Date: May 2006 Location: United Kingdom,Scarborough
| Not many people run caps on there motors but some do as it helps stall and it stops motor interference. |
| | #4 |
| Pebble Pounder Join Date: Nov 2006 Location: northampton
| Back in my elec racing days we used to run caps ALL the time. |
| | #5 |
| Quarry Creeper Join Date: Feb 2006 Location: Shillington
| I think you will find that the lathe motors generally do not generate enough RPMs to create radio interference. I don't use them on my crawlers and the motors for racing now have internal capacitors. |
| | #6 |
| Rock Stacker Join Date: Aug 2006 Location: South Charleston
| I run two 55 turn integy without capacitors, they are fine |
| | #7 |
| RCC Addict Join Date: Dec 2004 Location: Central NY
| I've never ran caps on mine and never had any problems. The only motor I've ever had that had caps was a POS sivler can motor that came in the TLT I used to have. If you wanted to run caps, its not going to hurt anything, but it also will probably not make a big difference. |
| | #8 |
| My truck started glitching a while ago and i put the 3 caps on and it stopped glitching and i also re-wired my truck and move my receiver away from the motor. I was running a Gd600 with a 65t lathe motor Regards james |
| | #9 |
| Thanks for all the help guys!! I was just wondering because I come from a stadium truck back ground and some of the modified motor I ran needed compaceters and some had preinstalled internal ones. I have almost got every thing to finish up my crawler. I just got some plexiglass or lexan today for about .50$ a piece to make my chassis. And Im making my links from aluminum rod that I am drilling and tapping. |
| | #10 |
| Rock Stacker Join Date: Nov 2005 Location: British Columbia CANADA
| no caps here works just fine |
| Thread Tools | |
| Display Modes | |
