Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: a few noob qustions...
Old 12-19-2006, 09:10 PM   #1
Default a few noob qustions...
1...i am usein a xxt tranny for a t case and was worndin what kinda shaft do i use to run to my tranny(i will most likey use a txt tranny)
and how do i mount the shoaft on the motro shaft?
2.how do i fit jato or maxx shafts on the xxt.
mudhunter is offline   Reply With Quote
Old 12-20-2006, 05:50 AM   #2
does the xxt use 2 set screws to hold the cup on the outside of the tranny ? if so use 2 set screws on the maxx shafts ( inplace of the 1 stock pin) just make sure you center the shaft when you tighten the set screws ( so it doesn't wobble) .
jrizza is offline   Reply With Quote
