Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: chassis
Old 12-19-2006, 10:57 PM   #1
Default chassis
Hey I was wondering if you guy could check this picture our and give me some feedback and tell me if you think it will work. i am making a chassis with 2 pieces lexan that will be separated by threaded aluminum rods. The red dots represent the link mounting points and the green dots is where the threaded aluminum is going to separate the 2 pieces. and the purple things are the electronics. Thanks for any comments and sugestion!!! Happy holidays!!
http://www.putfile.com/gt247life04
forgot to say its going to be ussed with clod axles
gt247life04 is offline   Reply With Quote
Old 12-19-2006, 11:08 PM   #2
The lower green dots are to low. You won't be able to get full compression because the driveshaft will hit your alum spacer.
PaulEZK is offline   Reply With Quote
Old 12-20-2006, 03:41 AM   #3
It should work fine, but I would move the upper and lower link mounts closer together.
BlueMonster is offline   Reply With Quote
Old 12-20-2006, 09:31 AM   #4
Is the lexan being used to make templates or are you going to run it with the lexan chassis
roddyf is offline   Reply With Quote
Old 12-20-2006, 09:43 AM   #5
He said the green dots are where the chassis seperaters are going to go, not where the shocks will be mounted.
Anyway, the lexan probably won't hold up on the rocks, unless you use dreally thick stuff. Also, you could epoxy 2 or 3 sheets of lexan together to make a kind of laminate. That would work very well, as it would flex more under impact.
4link4eva is offline   Reply With Quote
Old 12-20-2006, 03:19 PM   #6
Thanks everyone for the help. I think it lexan but im not sure. i got it out of a scrap bin at a plastic place for .50$ hella cheap and its 1/4 inch thick. when im done finishing it ill post some pictures.
Old 12-20-2006, 03:26 PM   #7
I understood that, personal experience tells me it(It=the alum spacer used to attach the chassis halves together) will hit the driveshaft when you try to articulate.
To fix it, just trade spots for your upper link holes, those should be lower anyways.
Old 12-20-2006, 03:31 PM   #8
He said in his first post that he was going to be using Clod axles, so no driveshafts to worry about.
trailduster79 is offline   Reply With Quote
Old 12-20-2006, 03:44 PM   #9
Wow.. I completely never read that part.
Old 12-20-2006, 03:50 PM   #10
In that case, I would suggest something like ah this..
The brown at the bottom being a skid plate of the same material.
Old 12-20-2006, 04:05 PM   #11
I usually stay away from threads like this because I end up unintentionally starting a fight. I'll try to fully explain my thoughts to avoid that.
When someone talks about building a chassis out of a non-standard material, I assume it means they don't have the tools or materials to build one right. To me this means you will be using hand tools and the build process will be time consuming and possibly sloppy.
I then ask myself, how much is my time worth. Your numbers will probably vary from mine on that one, but that isn't the point. The point is for $60 you can get a Vertical Smile Chassis that works very well for clod builds, or if you are not dead set on a 4 linked TVP chassis a Pimp Cane is less than $50. Even if you make $5 an hour, a Vertical Smile is like working 12 hours. Can you match the quality, functionality and style of that chassis in 6 hours?
If you are in it just for the experience of building it, more power to you. I appreciate the "I'd rather build than buy" mindset!
In the long run, if you are going to build it and then not be happy with it, you are way ahead of the game to buy something instead of wasting time and materials. If you have skills and want the experience, go for it!
*I am not advertising for either chassis I mentioned, it's just ones I have experience with and know the pricing of off the top of my head. Both are good, but there are many others to choose from.
Unholy is offline   Reply With Quote
Old 12-20-2006, 04:11 PM   #12
Woo hoo free advertising.. J/K
Double J is offline   Reply With Quote
Old 12-20-2006, 04:33 PM   #13
Well, speaking as someone who has "been there and done that", if he he a kid, and thus doesn't work, his time is worthless. So, with $0.50 worth of plastic and a load of otherwise useless time, he can build a crawler.
Old 12-20-2006, 05:08 PM   #14
That is true as well.
