Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Long travel shocks
Old 07-14-2015, 11:55 PM   #1
Question Long travel shocks
I'm looking for some extra long shocks that'll extend to about 140mm and compress to about 80mm. They're going on a 10th scale truck so I don't want some giant bore deals. Anyone out there seen such a thing? Thanks!
ToSte is offline   Reply With Quote
Old 07-15-2015, 01:28 AM   #2
I joined the Band!
Default Re: Long travel shocks
Look into the Icon shocks for the Yeti in 1/10 (10mm and 12mm bores) and 1/8 scale (16mm bore I believe). Axial has 12x65mm long Icon shock bodies (AX31190), so they should have the shaft and pistons for them as well. Maybe the 3x71mm (AX31054) or 3x77mm (AX31193) shock shafts will get you close to the 60mm of travel you're looking for.
Eric0424 is offline   Reply With Quote
Long travel shocks - Similar Threads
long travel shock's Cork 2.2 Scale Rigs 6 09-21-2014 05:57 PM
Axail Wraith long travel shocks ktmrider Axial Wraith 20 05-13-2014 05:47 AM
Long travel shocks f/r? xLPlushy Axial Wraith 21 05-27-2012 01:33 PM
long travel shocks xiteamxi General Crawlers 21 11-04-2011 01:27 PM
anyone with long travel 10 scale chromoly77 Non Crawler RC's 0 10-05-2010 12:15 PM
