08-30-2015, 11:58 PM | #1 |
Quarry Creeper Join Date: Aug 2015 Location: Grover, NC
| Drill holes in rims to vent.....or not?
Hi all, im new to crawling and have a question. I have a Axial SCX-10 Jeep Rubicon, I have a set of Axial 8-hole beadlocks on the way and im wondering if I should drill holes in them to vent/let water out?? With my stockers after every wet run I have to squeeze all the water out before putting up the truck. I have heard with beadlocks if you dont drill holes, water wont get it, but is there a disadvantage to this? Or should I drill holes to vent it? If so, how many holes and how big of holes do I drill and where? It kind of is a pain to have to squeeze out the water after every wet run, but if it is absolutely necessary then I dont mind it. Majority (if not every) run I do with my Jeep its getting in water What are some thoughts on this?? |
08-31-2015, 08:56 AM | #2 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
| Re: Drill holes in rims to vent.....or not?
It depends on the foams you run. Most people vent the tires, that way a couple high speed runs at the end of the day should clear out most of the moisture. I vent both the tires and wheels. You are not going to keep the water out, so the more exits the better, IMO. |
08-31-2015, 03:44 PM | #3 |
I used to vent the wheels it works for most foam set-ups. However in the last couple of years I've opted for venting the tires I use a 1/8" hole punch and one hole per tire is all you'll need it works great.
08-31-2015, 07:03 PM | #4 |
Rock Crawler Join Date: Oct 2006 Location: New Tripoli, PA
IMO I vent the tires, only because the tires will eventually wear out as opposed to the wheels....so I would rather punch a hole in a tire then an expensive wheel. But that's just me. Cheers, Wade |
08-31-2015, 08:59 PM | #5 |
Quarry Creeper Join Date: May 2015 Location: RRW
vent the tires, 1 hole every 90 degrees
08-31-2015, 09:17 PM | #6 |
Quarry Creeper Join Date: Oct 2012 Location: Malang, Indonesia
reading this axial thread on their blog might also help..
09-01-2015, 04:37 AM | #7 |
If you're using CI's Double Deuce foams venting the wheels is not an option. Those inner foams are practically air tight.
09-01-2015, 11:42 AM | #8 | |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
| Re: Drill holes in rims to vent.....or not? Quote:
I've always vented rims because holes in tires just don't seem right to me.... Just sayin. Never had an issue and all my rigs get CI foams right from the get go. | |
09-03-2015, 05:19 PM | #9 | |
CI's site even says use 2mm leather punch, evenly spaced holes....3 in every smaller tire....4 holes in every larger tire. Works for me too. | |
09-03-2015, 07:56 PM | #10 |
Newbie Join Date: Jul 2015 Location: Greenville
vent the rims, the air upon compression needs to escape
09-05-2015, 11:17 AM | #11 |
Quarry Creeper Join Date: Nov 2013 Location: alberta
Both my kids scx10's have the tires vented poking two small holes in the center of the tread across from each other using a hot soldering tip as for my tf2 its heavy enough that i dont see the need to vent.
09-05-2015, 12:13 PM | #12 |
RCC Addict Join Date: Oct 2012 Location: Norcal
| Re: Drill holes in rims to vent.....or not? |
09-05-2015, 12:37 PM | #13 |
I don't vent my tires or wheels... As long as I can get a good seal at the bead and the foam inserts are supportive. reason being... my 1:1 tires are sealed So in the name of scale... I follow that rule. I've vented tires before... but only on a racing rig, rolling a groomed, hard packed track. Even then... the foam inserts would be dust... When it was time to change the tires. But that was for competition... not every day use. Dirt mixed with moisture... inside the tire's interior is not good... no matter how one slices it. Imagine the tire's interior similar to that of a chicken's gizzard... gonna grind and muck up that insert but good... and it won't be consistent if it's ground to a pulp. Punching holes at the tire's OD tread surface... does not allow for complete evacuation no matter how fast one spins the tires. Sure some moisture will escape... But the dirt remaining will still be in there... and will eat away at the foam insert(s). |
09-05-2015, 02:39 PM | #14 |
Rock Crawler Join Date: Jun 2015 Location: In the Sticks in the Ozarks
jmo, I vent the wheels (2 holes, opposite ea. other) then if I'm planning a wet run I'll put a piece of electrical tape over the holes to help keep most of the water out.
09-05-2015, 10:16 PM | #15 |
Newbie Join Date: May 2009 Location: Reno, NV
I vented the rims on mine. They're the stock wheels that came with my ax10 so I didn't mind putting a small hole in them. I've gone through alot of mud puddles over the years and haven't had issues with water getting in.
09-08-2015, 01:10 AM | #16 | |
Drill holes in rims to vent.....or not? - Similar Threads | ||||
Vent HBs or vent the rims or both? | boisetrucker | Tires and Wheels | 10 | 12-27-2009 05:58 PM |
Vent holes in rims or not | rocresq | Tires and Wheels | 21 | 05-20-2008 12:55 PM |
Aluminum Rims and Vent Holes???? | RCholic | Tires and Wheels | 15 | 12-10-2007 01:50 PM |
rpm claw 2.2 rims...no vent holes...big deal? | the fn show | Tires and Wheels | 6 | 09-09-2006 08:17 PM |
vent holes | Bknight | General Crawlers | 0 | 01-28-2006 09:57 AM |
