12-29-2006, 02:31 PM | #1 |
Pebble Pounder Join Date: Sep 2006 Location: Minnesota
| Wheely King, CXT, camper trailer, now with pics!
I'm cleaning up my original post!! I've got a Wheely King, see pics below. a 1/10th New Bright CXT body http://www.newbright.com/search1.cfm?id=373 But all black, and different tires/wheels. The plan is that body on the Wheely King. I'm planning to build a camper to look like my 1:1 camper: That's my new toy hauler and R/C pit trailer 8-) I moved my tire/wheel questions in the tire/wheel section. Frame material, I think I can figure all that out from my million hours of reading on this forum, (thanks guys ) and some fab work I've done in the past (not R/C related). Trailer suspension.... I'm actually good at on my own :-P 2 or 3 sets of Tamiya Juggernaut springs will be ordered shortly, depending on how many axles I decide on. The body of the camper.... I'd like to keep construction time down to a minimum, and not get concerned (at least yet) about interior details, I just want to make a shell. I figured polystyrene sounded like a good material to use. But this will be my first time working with the stuff. Is it possible to make the entire shell from thick sheets and have no internal frame/stiffners, and just glue the seems? And what thickness? Weight is really not a concern. The sides of the camper will be between 31" (if I make it scale) to 40" long, and I haven't seen sheets that large (24" is longest I've seen), so I'll end up with a seem down the side unless someone knows of larger sheets somewhere. Is this a better initial question? Last edited by swhenrik; 01-04-2007 at 09:19 AM. |
12-30-2006, 06:18 PM | #2 |
Quarry Creeper Join Date: Feb 2006 Location: Shillington
| That is too much info and I didn't make it past the second paragraph like the other 50 people that checked out this thread. The best advice I can give you is: treat everyone in here like they are 4. Use small words and lots of pictures!! Action figures are a plus. |
12-30-2006, 07:05 PM | #3 |
Quarry Creeper Join Date: Dec 2005 Location: ST LOUIS.MO
my next door neighber has one "wheely king".he always wants to race my stampede.we raced 2 times and i out ran it .i gave it the new name of wheely queen!
12-30-2006, 07:58 PM | #4 | |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
12-31-2006, 11:54 PM | #5 | |
I was wondering why the lack of responses.... I guess I overloaded the question! Action figures, LOL, but then I'd be copying MNSTER. A Stampede is definitely a different style of truck, not really a fair comparison. Quote:
I picked up the truck today. Interesting! Way too fast stock for in the house. If I can get someone to answer about a lathe motor vs. a GD600, I can get that problem fixed. Looks like I can cram the GD600 in, but if a lathe would work, it would be a lot easier. Taking out the rear brace on the suspension links leads to LOTS of torque roll. Oh well, it's staying out. There's actually LOTS of articulation with it removed. The spring rates are nice and soft, but the shock oil is way too thick. I dropped in a NMT diff in the front end. I took a NMT drive cup for the center, reamed it larger to fit on the tranny, along with a NMT center shaft, so I'm part way to 4wd. Just gotta figure out a way to get the shafts to the wheels working. Once I do, I'll get pics up of what I did. Interesting that the truck uses 12mm hexes, but also comes with 14mm hexes (Maxx wheels).... too bad I want to go smaller with the tires/wheels! Getting the CXT body on will only require a slight increase in wheelbase. But I'll want to keep the width down to make it look decent. | |
01-01-2007, 12:12 AM | #6 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
if wieghts not a concern id build some kind of framework and sheet it. unless its just gonna sit on a shelf you want some kind of strength/reinforcment for when you run it
01-01-2007, 12:32 AM | #7 |
Stick with the stock motor or try a 45 or 35 turn motor if you want any speed. The 55t is slow. The GD should slow that stock motor down about like a 55t
01-01-2007, 01:39 AM | #8 | |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
01-01-2007, 11:51 AM | #9 | ||
1. Suggested motor or gear reduction for 1/2 speed of 27 turn? 1. Touring car wheels with bearings? 2. Would polystyrene would be a good camper shell material? 3. Would I be better off making an internal framework and uses thin material, or skip the frame and use thick material? (For the camper) 4. Is there polystyrene sheets in sizes larger then 24" long? 4wd is almost complete..... I should be done about the time the parts are available from HPI | ||
01-01-2007, 11:59 AM | #10 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
Firstly, hello and welcomne to the forum Giving us pics of the truck would help us hugely to give you good advice that will work, so post up. As the Wheely King is so new, nobody really knows about it, so we don't know fast it is and how much a slower motor would slow it down by. But, at an educated guess, I would say a 55 Axiom lathe motor would halve the speed for you. For wheels, the stock TLT ones would be the easiest and cheapest to find, but they might be a bit too small. Another thing, if your truck is 4wd, why do you need wheels with bearings? I think thick polystyrene would hold up OK unless it took a bad fall down a large hill and onto a conveniently placed rock. Good luck with your build ahead Last edited by 4link4eva; 01-01-2007 at 12:02 PM. |
01-01-2007, 02:33 PM | #11 |
Quarry Creeper Join Date: Dec 2005 Location: Albuquerque
| http://www.newbright.com/search1.cfm?id=415&imgonly=yes you mean that one thats not all blinged out?
01-02-2007, 07:49 AM | #12 | |||
No pics yet, as there's nothing original about the truck yet. HPI has a LOT of pics: http://www.hpiracing.com/kits/kitMain.php?partNo=10820 JIA has a few pics up, and a video. 55 turn sounds like it would be perfect.... anyone else know? TLT tires/wheels... I was aiming for something a bit more scale looking, like narrowed Geolanders for example. The height of the Pro-Line Dirt Hawgs looked pretty good under the body, just too wide. Wheels with bearings are for the trailer. The trailer isn't going to see the serious off-road stuff. Quote:
I got the truck converted to 4wd.... It "off-roads" a lot better now! But no pics yet, I'll try to get them up tomorrow. Last edited by swhenrik; 01-02-2007 at 07:52 AM. | |||
01-02-2007, 09:24 PM | #13 | ||
Rock Stacker Join Date: Nov 2006 Location: NOVA
I can't believe you get here before you realized this Quote:
01-02-2007, 10:05 PM | #14 | |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
01-03-2007, 07:36 AM | #15 | |
01-03-2007, 09:41 AM | #16 |
Here come the pics!!! From my post in another thread: These are NMT and WK parts: HPI A431 Diff case for NMT HPI A850 bevel gear set NMT HPI A855 Ring/pinion NMT HPI B030 10x15x4 bearing (Or Avids) HPI B022 11x5x4 bearing (Or Avids) These are non-WK parts I had to use: HPI A553 NMT rear center dogbone (Perfect length!) HPI 72107 NMT drive cup, center (hole must be bored larger) HPI A558 NMT drive cup, diff outdrives HPI A559 NMT drive cup, diff input The NMT has outdrives (drive cups) on the diff, the WK does not, but the drive cups are needed for my method, and will easily fit inside the axle. I used a piece of 1/4" steel rod to make dogbones to drive the wheels. One end slips into the drive cup on the diff, one end slips into the drive cup at the wheel. This must be used at the BACK of the truck, with no rear steering. Therefore move the rear axle to the front and vice versa before starting. I cross drilled the ends of the 3/8" rod and pushed pins into the holes to make it look like a dog bone. The drive cup I used (72107) didn't fit on the WK tranny, I had to enlarge the hole. Using a drill bit was a waste of time, and a waste of about 4 drill bits! A dremel with a tiny stone and a lot of patience and I got it to fit on the WK tranny. Last edited by swhenrik; 01-04-2007 at 11:31 AM. |
01-03-2007, 09:47 AM | #17 |
Other pics.... Oooo, aaaah, a stock Wheely King: Mandatory flex shot: Try the Nitro MT tires on it: Looks OK with the suspension fully compressed: Last edited by swhenrik; 01-03-2007 at 09:56 AM. |
01-03-2007, 10:04 AM | #18 |
Hmmm... some 14mm hexes came with the truck, I'll go grab some Maxx size tires, in this case Maxx Masher 2000's on Maximizer beadlock wheels: OK, that looks stupid! The tires rub when steering at all, so 1/2" offset wheels would definitely be needed. What else do I have laying around? Can't seem to find the Big Joes, although they'd look even more stupid. I got some Savage tires, the 1/18th Nylint junk, etc: Could drive right over that Nylint (Why did I buy that thing again?): Last edited by swhenrik; 01-03-2007 at 11:55 AM. |
01-03-2007, 10:10 AM | #19 |
What else I got laying around? Hmm, being the Bronco body is so popular, maybe some people would like to see that on there?: Of course the wheelbase is wrong. And that poor body has seen better days!!! What else? Pro-Line Silverado body? No, the pic came out bad. Parma Blazer body?: Wheelbase still wrong. And that one has also seen better days, I'm showing the good side! |
01-03-2007, 10:13 AM | #20 |
The CXT.... now I admit this looks like a newb pic..... I guess it kind of is a newb pic: Gonna take some work to get it to sit low enough, and of course extend the wheelbase. Front view actually looks OK, even with the huge WK tires: |
