10-13-2015, 09:45 AM | #1 | |
Newbie Join Date: Jul 2015 Location: singapore
| Dilemma in choosing types of axles, advice please.
I am planning a rather ambitious scale rc car based on the mobile russian ICBM launcher. there will be 8 axles as per the actual vehicle. here's the dilemma, the actual veh in real life has double wishbone style with transmission shafts and transfer cases running along the length of the chassis. double wishbone is easy to build if there are just 2 axles. But it becomes tricky when there are so many. I did my research, there are only 2 instances of multi-axle builds that do not use solid axles. Quote:
the other solution is actually uses bevel gears and transfer cases, a different approach from the russian guy's. it might be cheaper but definitely more machining needed and more complicated. My question is: I am not sure whether I should try to build it similar to the actual vehicle in real life, with double wishbones OR use solid axles altogether. the vehicle is expected to be 1.3m or nearly 10feet in length. so it's probably not going off-road unless it's wide-open grass/sandy fields. | |
10-14-2015, 12:48 AM | #2 | |
| Re: Dilemma in choosing types of axles, advice please. Quote:
* Scale realism, with lots of work and costs involved, or * Keeping it simple and cheapish. I don't expect anybody to spot the difference from a distance... Which is it, 1.3m (4.3ft) or 10ft (3.0m)? | |
10-14-2015, 10:05 PM | #3 | |
Kept thinking about other things Yes it shld be 4.3ft | |
Dilemma in choosing types of axles, advice please. - Similar Threads | ||||
video file types, need some advice. | BigSki | Scale Videos! | 3 | 12-30-2010 02:38 AM |
Need advice choosing ESC for Honcho | yellorover | Axial SCX-10 | 20 | 01-01-2010 03:36 PM |
advice for choosing a first crwaler | dirtymike | Newbie General | 11 | 09-07-2009 06:41 PM |
Newbie seeking advice on choosing tires for Wheely King to make it more realistic | painter4x4 | Newbie General | 13 | 06-14-2008 09:10 PM |
types of axles | mudslinger74 | Newbie General | 10 | 02-13-2006 08:41 AM |
