Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Wraith Spawn Builder Kit?
Old 10-28-2015, 11:15 AM   #1
Default Wraith Spawn Builder Kit?
So I am 100% new here. I am not new to RC. I have a solid stable of Short Course trucks. We have a rad track. I want to add a few crawlers to the mix and build a rock section for our track. Thus giving us a little Ultra 4 action. I need help setting this thing up.
What motor/ESC setup? What servo?
I picked this up.
UTVUGRUSTY is offline   Reply With Quote
Old 10-28-2015, 02:42 PM   #2
Default Re: Wraith Spawn Builder Kit?
I'd suggest starting with Harley's stickies in the Wraith section. After that, a search on "Wraith Ultra 4" will pull up plenty of good threads with U4-specific setups. If you still have questions at that point, fire away...
new2rocks is offline   Reply With Quote
Old 11-19-2015, 10:32 AM   #3
I am making progress.
Old 11-20-2015, 09:33 AM   #4
Servo relocate in progress. Cutting carbon plates today.
This is a sample of the finished product.
So far axle housing has been machined.
Old 11-22-2015, 04:17 PM   #5
Got to test it a little this morning. It was very still and very little flex.
Old 11-22-2015, 04:18 PM   #6
I bled the shocks and it has way more FLEX.
Old 11-22-2015, 06:58 PM   #7
Cool.
Biomedchad is offline   Reply With Quote
Old 11-22-2015, 11:03 PM   #8
KOW practice.
Old 11-23-2015, 09:14 AM   #9
Groove and sipe those trepadors and they will work a lot better!
YJ4Rox is offline   Reply With Quote
Old 05-31-2016, 12:12 PM   #10
I stripped out my spur gear. What's a decent upgrade? Should I change the number of teeth, plastic or metal?
Old 05-31-2016, 07:53 PM   #11
I can't really offer up any advice on gearing since I like my trucks under 8mph(crawlers anyways) and will crawl up a wall almost. But as far as material I run Delrin Spurs in all my trucks. My scx wraith slash(brushless) and a few others all have Delrin Spurs and when they break I'll run them again. It's 50/50 on people I've talked to about metal or plastic in their opinions and sure it's the same here. I like Delrin because for one it's a self lubricating plastic, also it's a little harder than normal stock plastic Spurs, it's machine cut vs just pressed into shape. I don't like metal just because you need a weak link somewhere(for the most part and everyone likes different stuff which makes this a awesome hobby and this is just my opinion. Not sure if it's right or wrong) and I'd rather break a spur vs something more expensive. Just my opinion and hope it helps=) I think it's the best of both worlds.
Betts818 is offline   Reply With Quote
Wraith Spawn Builder Kit? - Similar Threads
Wraith spawn kit Mitchell72 Axial Wraith 6 10-29-2015 03:58 PM
Yeti kit or Wraith Spawn kit? The Dark Knight Axial Yeti 3 09-25-2015 10:09 AM
New Wraith Spawn Kit mikl Axial Wraith 9 05-26-2015 10:02 AM
wraith rtr/builder kit , ax10 ridgecrest or scx10 kit hocho/dingo xC Pirates Newbie General 9 06-09-2012 07:54 AM
