11-22-2015, 09:25 PM | #1 |
Newbie Join Date: Nov 2015 Location: port alberni
| performance of upgraded axles
Reeding all the dream builds of RC's that have me drooling. The vanquish and SSD axles look like candy but do they offer much in performance or is this something I should only consider when I break the axial oem stuff on my scx10. I have axial aluminum knuckles and c hubs on the front. Just trying to get more knowledge and the search function sometimes leads me a stray. If it is simple as a link please post the link won't offend me.
11-22-2015, 10:15 PM | #2 |
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
| Re: performance of upgraded axles
The extra weight down low probably helps a bit with traction and stability but aluminum doesn't slide over rocks as easy as plastic. Stronger? The VP (and SSD I assume) ones are certainly stronger. Integy/other cheap off brands, probably not. SSD also has the D60 plastics housings, I have set and they seem nice, time will tell how strong they are. I also have the Curries on my Wraith and they're dead sexy, I cringe a little every time I drag one over a rock My only complaint with them is it's a bit more work to disassemble them vs the stock stuff. |
11-22-2015, 10:23 PM | #3 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
GCM also makes some nice scale housing , both GCM and the SSD have removable gear covers , so you can open them up and check it out very quickly.
11-22-2015, 10:24 PM | #4 |
| Re: performance of upgraded axles |
11-22-2015, 10:40 PM | #5 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
| performance of upgraded axles Definitely. As far as durability is concerned, the stock housings are pretty good. I just ripped one for the first time after a year and a half of heavy abuse (ROC 412 on 3S and driven hard). With beef tubes added, you won't get more durable than that. But with the snapped housing, I swapped over to the SSDs for appearance and ease of servicing. I haven't run them near enough to report on durability, though I suspect they'll be at least as strong as the stockers, and maybe more so. From a pure performance perspective, all else equal, plastic beats aluminum because of ease of sliding over rocks. The biggest limiting factor is the size of the pumpkin, which is dictated by Axial's large ring gears. If you're not itching to make a change, I'd suggest running the stock housings until one of them breaks. At that point, you can make a switch to something like the SSDs or Curries if you really want to go over the top. Last edited by new2rocks; 11-22-2015 at 10:55 PM. |
11-22-2015, 10:40 PM | #6 |
Quarry Creeper Join Date: Aug 2014 Location: sacramento
Rockjock curries will take a beating over two years of beating and two axialfest's still going strong, but yes they don't slide as easy as plastic
11-23-2015, 05:11 AM | #7 |
Newbie Join Date: Nov 2015 Location: Sweden
Hi Im new here. Anyone know if SSD sells complete axles? I looked at Vanquish, but they dont sell complete axles? Seems to be hard to find complete upgrade axles for sale!? I couldnt find axles at GCMs webb anymore. I would like 4WS for my custom build. /Sam |
11-23-2015, 05:55 AM | #8 |
Quarry Creeper Join Date: Oct 2010 Location: Nashville TN
rc4wd is the only company I know of that sells complete running axle sets. and many of them have notorious weak spots if you drive them too hard. SSD and Vanquish make very nice upgrades for existing parts but neither of them make every single component so in other words; no. I recommend just ordering the specific parts you need and assembling them yourself.
11-23-2015, 08:27 AM | #9 | |
| Re: performance of upgraded axles Quote:
GCM has stuff that's not on their site. If you send an email, Chris will let you know what he has. But FYI, his Terramods (as well as many of the upgraded axle housings, like the SSDs and RC4WD D44s) are designed for CMS, not an axle mounted servo. Unless you plan on CMS front and rear, you'll be limited to axles that allow for a servo mount. Sent from my iPhone using Tapatalk | |
11-23-2015, 09:18 AM | #10 | |
GCM Racing WebStore-2015 - TerraMod Axle Housing - PreOrder They have options for the fully built axles. ( Option #4-183 and Option #5-183) | |
11-23-2015, 01:23 PM | #11 | |
11-23-2015, 01:31 PM | #12 | |
Well Iike dont like the look of axlemounted servos, but today Im not 100% which I will go. I will go for metal housing axles. | |
11-23-2015, 01:33 PM | #13 | |
Good tips and tricks from I belive Chris him self!? | |
11-23-2015, 03:00 PM | #14 | |
11-24-2015, 01:32 AM | #15 | |
11-24-2015, 08:55 PM | #16 |
Just noticed something...SSD sells an axle servo mount plate for their D60 axles as a separate option for the axles. In theory, that would allow 4WS with servos on both axles, but I haven't tried it to be able to say for certain.
11-25-2015, 01:12 AM | #17 |
Hi, anyone running rc4wd "monster digger" axles? They look fantastic, but the size is big. 273mm wide. How wide are axial wraith axles? I found a earlier thread here about these axles but couldnt find any info if they are strong and good quailty ? (Sorry for bad spelling if so) /Sam |
performance of upgraded axles - Similar Threads | ||||
Upgraded axles for TF2 | desertdude | RC4WD Trail Finder 2 | 6 | 10-01-2015 01:01 PM |
