02-10-2016, 08:24 PM | #1 |
Newbie Join Date: Jan 2016 Location: Northern,NJ
| Cant seem to find a tire that fits RC4WD wheels??
I bought a set of OEM STAMPED STEEL 1.9 BEADLOCK WHEELS and 1.9 dirt grabbers all terrain and the tire wont fit the rim and cant seem to find a match for it heres the specs of rim Specifications: Stamped Steel Wheels Amazing Detail Fits Standard 12mm Hex Wheel Size: 1.9'' OD: 1.9in / 48.3mm Width: 0.96in / 24.3mm Center Hole OD: 0.17in / 4.2mm Negative Offset: 0.31in / 7.9mm Each Weight: 2.15oz / 61g |
02-10-2016, 08:38 PM | #2 |
Quarry Creeper Join Date: Jul 2008 Location: us
| Re: Cant seem to find a tire that fits RC4WD wheels??
Do you have pics? If they are the beadlocks you have to take them apart to install them, remove the 6 bolts, place the ring inside the tire. Put the 2 halves back together, reinstall the screws and done Sent from my iPhone using Tapatalk |
02-10-2016, 08:40 PM | #3 |
Rock Crawler Join Date: Jan 2010 Location: [loh-key-shuhn]
How exactly does the tire not fit the rim? RC4WD ships many of that exact combo with Gelande II kits. |
02-10-2016, 08:45 PM | #4 |
| Re: Cant seem to find a tire that fits RC4WD wheels?? Those tires look wider, Whenever i put one together i have to force it and the rear bead keeps popping out and the tire sticks out funny ill upload a picture soon
02-10-2016, 08:49 PM | #5 |
Are the tires 1.55? With 1.9 rims? Sent from my iPhone using Tapatalk |
02-10-2016, 08:50 PM | #6 |
| Re: Cant seem to find a tire that fits RC4WD wheels?? |
02-10-2016, 08:52 PM | #7 | |
Quarry Creeper Join Date: Oct 2014 Location: Milpitas
| Re: Cant seem to find a tire that fits RC4WD wheels?? Quote:
Those rc4wd wheels have been the bane of my existence. If you want a wheel that looks great and will go together easy choose rc4wd race lines. OR Gear Heads. Gear Heads will go together easy no matter what tire and I have tested most. Rc4wd wagon wheels in particular have left me tearing my hair out. | |
02-10-2016, 09:13 PM | #8 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
That particular combination should be very easy to mount. I've done it many times. I start by pulling all 3 pieces of the wheel apart, inserting the beadlock ring inside the tire, then holding the inside and outside faces of the wheel in place while tightening the screws and nuts. If you're still having trouble, some pix and an explanation of how you're trying to do it would help.
Cant seem to find a tire that fits RC4WD wheels?? - Similar Threads | ||||
RC4WD Mickey Thompson Wheels w/ non RC4WD tire | NewbieRC361 | Axial Wraith | 2 | 08-12-2013 11:19 PM |
need new motor cant find one thats fits my needs | fordlightning + jeep | Newbie General | 10 | 11-01-2011 09:24 PM |
Wheels for Berg what fits ? | toy4crawlin | EnRoute Berg | 24 | 08-02-2009 01:03 PM |
