02-25-2016, 01:59 PM | #1 |
Rock Crawler Join Date: Dec 2015 Location: Charlotte, NC
| Lowering COG but lose ground clearance?
It seems like lowering the center of gravity is important for crawling. In doing so, aren't you losing ground clearance which I would think is also important for crawling? Does one take priority over the other? What's the best way to account for both of these things in design of your rig?
02-25-2016, 02:09 PM | #2 |
Pebble Pounder Join Date: Feb 2016 Location: Shelby
| Re: Lowering COG but lose ground clearance?
Simply putting weight down low will help lower cog without changing ground clearance
02-25-2016, 03:09 PM | #3 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Center of gravity is far more important as it affects climbing, side hilling, and even how your suspension geometry reacts. With bent rear links and /or chassis lean ground clearance isn't really an issue.
02-25-2016, 04:56 PM | #4 |
Rock Crawler Join Date: May 2009 Location: Welderville just south of benchviseland
| Re: Lowering COG but lose ground clearance? x2 I'd take a lower cog and even weight distribution over super ground clearance any day of the week... Believe it or not, my Trailfinder 2 out-crawls my scx-based rig just because it has a lower cog and even weight distribution |
02-25-2016, 05:11 PM | #5 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
Low cog....then pick good lines
02-25-2016, 06:05 PM | #6 |
Okay. What are the common mods I need to lower cog?
02-25-2016, 06:31 PM | #7 |
It's all weight distribution... I've found that motor-forward setups with a transfer case that sit lower in the chassis to be effective. You want to maximize your suspension travel without increasing ride-height. Using taller shock hoops will help with that.
02-25-2016, 06:35 PM | #8 |
What do you mean by shock hoops? Taller shock mounts to lower the ride height?
02-25-2016, 06:39 PM | #9 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
| Re: Lowering COG but lose ground clearance? On what truck? They make lowering kits aka droop kits for the wraith, scx10 etc. They simply raise the upper shock mounting location for a lower ride height. I run my rigs about as low as they can go. I'll take a few belly-drags over a tippy rig any day. |
02-25-2016, 07:11 PM | #10 |
Bomber
02-25-2016, 08:19 PM | #11 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Bomber is pretty limited, but flip link/shock mounts on axle, shorter shocks or run no preload on spring collars and/or get softer springs so at ride height your shock shaft sit half way in the shocks instead of fully extended out.
03-10-2016, 04:32 PM | #12 |
Newbie Join Date: Mar 2016 Location: B.G
Lower the better or atleast thts wht I've found out with my driving style
03-10-2016, 06:09 PM | #13 |
Shorter shocks seems counter intuitive for better crawling...I have a lot to learn.
03-10-2016, 06:13 PM | #14 |
Flex is over rated try and stick with atleast tire height of flex anything over tht is useless in my opinion
03-10-2016, 06:20 PM | #15 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
Low slung rigs not only look better they are far more predictable and less prone to role overs. I like to run an internal and external spring on my shocks. The 2 spring set up works amazing for me. I know what my rigs are going to do and they spend very little time on their lid. |
03-10-2016, 06:24 PM | #16 | ||
| Re: Lowering COG but lose ground clearance? Quote:
Trust your line driver! Practice makes perfect. This too. I also don't like huge tires, stock size-ish is better. | ||
03-10-2016, 06:27 PM | #17 |
Why run an internal spring and external spring? Ivery only seen people run one or the other
Lowering COG but lose ground clearance? - Similar Threads | ||||
Lowering COG in LNC | scotty_h | Team Losi Comp Crawler | 12 | 01-29-2015 02:00 PM |
lowering your wraith cog | kakachille | Axial Wraith | 2 | 01-25-2013 08:57 PM |
tire clearance and lowering C.O.G | -BIGMAXX- | Team Losi Comp Crawler | 26 | 11-19-2011 03:21 AM |
Lowering COG Help Needed | BMFOTP | Newbie General | 52 | 04-10-2009 04:59 PM |
(TLT) gaining more ground clearance without raising cog? | hpi_jeep | Tamiya TLT Crawlers | 3 | 02-13-2005 02:19 PM |
