03-28-2016, 09:43 PM | #1 |
Newbie Join Date: Mar 2016 Location: barstow ca.
| bomber vs yeti
Hi im new to rc crawling but not rc and i have ordered a bomber and am going to attempt to make it competitive with my bros yeti now i understand these are 2 different platforms and im going to gut stock electronics and put my tekin set up in and savox servo and dx3r radio yadda yadda ....My true question is since im new to crawlers is about getting it to handle at speed and on the rocky stuff also what parts needed to swap for reliability and strength any info would be appreciated .... Thanks
03-28-2016, 10:02 PM | #2 |
Quarry Creeper Join Date: Aug 2008 Location: Sweden
| Re: bomber vs yeti
You should get a rear swaybar if you want it to handle good at any speed! With more power my first upgrades would be drivelines and steering links. Try check out the bomber section on the forum lots of info! |
03-28-2016, 10:32 PM | #3 |
Rock Crawler Join Date: Mar 2015 Location: "Crawling Heaven"
| Re: bomber vs yeti
Foams are a huge factor, shocks, links, and yes, a sway bar __________________________ 1.9 Ibex tuber - The Merica ibex. R.I.P Dave Mirra |
03-29-2016, 05:36 AM | #4 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
| bomber vs yeti
X2 to the sway bar and new shocks to lower it. But how to set it up all depends on where and how you plan to run it. If your brother is running an open front diff, you won't be able to handle turning at speed (think pavement or race track) with the Bomber's locked front diff anywhere near the way he can with his truck. But he won't be able to crawl on rocks with his Yeti anywhere near as well as you can. My advice would be to start by swapping out your electronics, adding the sway bar, universals n front, and doing the basic durability mods (lockers, links, trailing arms, knuckles/chubs). You can either start with the stock shocks and tune them with springs and oil, or swap them for shorter shocks to help lower it. Then go run it with your brother to get a feel for the setup and what you want to tweak next. You'll probably find that your RR10 can do some things better than his Yeti and vice versa, and you'll have a much better idea of where you want to go. And if you post some video showing where and how you run it, it will be a lot easier to help you from there.
03-29-2016, 09:13 AM | #5 | |
| Re: bomber vs yeti Quote:
03-29-2016, 10:14 AM | #6 |
Rock Crawler Join Date: Feb 2010 Location: Central/SE Ohio
| Re: bomber vs yeti
Widen the stance, do an ifs conversion, unlock the front diff, get the cog low as possible.....stiffer foams shorter mm shocks.....
04-09-2016, 12:27 AM | #7 |
Newbie Join Date: Mar 2015 Location: Chino valley
| Re: bomber vs yeti
Once you get your rig you will find out fast what you need to replace and what you don't! Try to get to some rc events in your area to see and talk to other people about what they've done Sent from my iPad using Tapatalk |
bomber vs yeti - Similar Threads | ||||
Yeti vs Bomber | cullen colapietro | Axial Yeti | 26 | 10-06-2017 06:21 PM |
Yeti Motor/ESC in RR10 Bomber | sean_cj7 | Axial RR10 Bomber | 27 | 09-11-2017 02:15 PM |
Bomber/Yeti Trailing Arms | Blue Monkey RC | Axial RR10 Bomber | 13 | 03-16-2016 11:26 PM |
Do i want a Yeti or Bomber | winsler | Newbie General | 14 | 02-28-2016 01:19 PM |
Wraith VS. Bomber/Yeti Transmission | Jayn | Axial RR10 Bomber | 6 | 01-15-2016 07:20 AM |
